Bolts connecting LBJ to hub?
fluffeh
I recently replaced my CV's and found I was missing two of the bolts on my driver's side that connect the LBJ to the hub. Thank God I changed the CV's when I did and the other two didn't fall out on the highway.
So anyway, I took one from the other side and now I only have three bolts on either side. I actually used thread lock this time so they should hold but I need to replace the two that I lost.
Does anyone know what kind of bolt that was and/or where to get the right one? I'm afraid to just go to the hardware store because something tells me those bolts need to be stronger than average. So any info on that would be greatly appreciated.
Also, while I'm posting, I lost a lot of diff oil changing my CV's and I suppose I should probably refill the diff. What kind of fluid should I use? And should I just change the whole thing while I'm at it?
Thanks in advance!
Part# 90080-10066, though that number may have been changed. The dealer will know what you need. Get there today.
Any 75w-90 is good.
kimyuseung77
