I would be interested in adding a dedicate switch for the heated mirrors. Most of the time when I use the rear defrost it is only because I need to activate the heated mirrors.
I think it's a bad design when you have two hot wires next to each other. Whereas most cars I see have wires on each end. Putting two wires next to each would create too much heat and too fast.
Toyota glass seems to be crap overall, at least in my experience. I've seen enough reports of this happening on our 4runners to use my rear defrost as infrequently as possible, but I've had a long history of having problems with the garbage glass Toyota seems to be producing. First problem came on my parent's Tundra, the rear view mirror simply fell off, however the epoxy was still in place and it ended up taking a huge gouge out of the glass itself, so after the warranty replaced the windshield with a brand new Toyota piece it got a TINY chip that quickly spider-webbed into another replacement maybe 1 year later. It seems it takes very little to ruin windshields fitted to Toyotas, so I suspect the rear glass is of equally-questionable quality.
So far they are on their 4th or 5th windshield, but the most recent one was aftermarket and has lasted about 7-8 years now. On a side note, my woman's 2002 CLK Mercedes had a HUGE rock simply bounce off it on the freeway with no damage whatsoever (twice when I was driving actually), same goes for my old Mercedes and BMW, but I know something 1/10th that size would have ruined my 4runner's windshield in a second.
wow, my rear glass is etched terribly from previous owner. I am not going to use the defroster any more after reading this! My truck is at the body shop right now with a smashed in tailgate. Unfortunately, the body shop plans on putting my old glass into a brand new ordered OEM tailgate. Maybe I should talk to them about putting in new glass after reading this! They did not adjust for that so I would have to pay for it.
How many times have you heard of this? This is the first time I have seen someone saying it happened? It can't be a common occurrence. I've used my defroster for years without it exploding...
Is it true that if you press the defroster button whilst driving the back window will explode...?
...Yes...
haha
Why do you want a picture Blackworks? I dont understand what you are trying to look at?
I guess ill just pull the fuse then so I don't accidentally use the defroster... Its never really that bad. And its not hard to do a quick walk around knocking off the snow before driving off.
... Why do you want a picture Blackworks? I dont understand what you are trying to look at?
