thewaydown
In a previous post I mentioned I just purchased an 03 4.0 v6 a few days ago. The coolant in the reservoir was low, and upon checking at home with a combustion tester, realized that the coolant was low in the radiator (could not see any upon removing the cap). It passed the combustion test (used one of those fluid testers). Has no codes, normal idle on cold start. No film under oil cap, tranny fluid is clean. Haven't investigated for radiator/water pump leaks, but haven't seen anything noticeable. Decided to pull #6 and #4 spark plugs and put a borescope inside to check for coolant in the cylinders.
I am not familiar with HG leaks, or what a healthy cylinder looks like. I did, however, get a few pictures of the spark plug wells, and inside the cylinders. The wells were dirty at the bottom, and there was this greenish liquid about midway up the outside of both of the coil packs, it didn't smell like coolant, just smelled like combustion. #4 spark plug well looked dirtier than #6. The heck is all that gunk? It doesn't look like there is any liquid inside the cylinder, but the tops of the heads look a bit corroded/rusty? Like I said, I have no experience.
Here they are.
Here they are.
