Bought a damaged 2014 4runner SR5
Blck14runner
Got a front end damaged 4Runner posting photos as I go
Pulling and cutting
Drilled out the bent up apron on the passenger side and installed a new one
Putting it back togetwr
Got a new hood, bumper cover, passenger fender, headlights, rented a paint booth and painted all the parts
Finishing up the build... for now
Installed the bumper had few other things I needed to fix like tie rod, axle boot was ripped, ABS sensor wiring was damaged, fixed it over 3-4 weeks was a light project
Installed a 3” rough country lift
Got my lift kit in yesterday went with a 3” rough country lift, and got 295/70r17 tires getting them installed later today, last two photos are before/after installing the lift
Tires/alignment
New tires and alignment after the lift, next is spacers and painting the rims black
WOW ! Nice job man.
Did you get a super deal on the broken runner ? The front you just repaired is toooo shinny ! lol you need to scratch it up a bit if you know what I mean hehe.
WOW ! Nice job man.
cost me pretty good under 14.5k back to fully stock not counting the lift or tires but i did all the work so i saved a lot there
Nice work OP. What doe you do about the stock air box? Looked pretty mangled in you first pics. Did you replace it or go with a CAI?
Also, did you do a BMC for the 295's? rubbing?
air box was mostly fine just the lower part of it was cracked/missing, Went cold air intake bought it online kinda crappy tho might do something else later on, only pic I have of it right now
ya i went 295 and a little rubbing so i need to trim some the fender liner/mud flap
nice, if you decide to go another direction, back when I did my CAI, buying the TRD one in pieces was the cheapest option, Parts list... http://www.toyota-4runner.org/5th-gen-t4rs/85960-how-guide-trd-cai-installation-22.html
If you want to go stock, plenty of guys here that have upgraded would probably give you their old parts.
thanks good to know, think ill stick with this one for now, it almost sounds like i have a turbo when im driving around 2600-3000rpms has a whistle to it, next things im planning are paint rims black, offroad bumpers, silders, roof rack hoping in the next half a year
ABS code c120a
So I was reading around and it seems like since my abs wire was damaged it made a c120a code come on but I can’t seem to clear it was wondering if any one please let me know how? I have a obd scanner and it can reset the code but doesn’t seem to be clearing
Try a zero point calibration, if you have downhill assist calibrate it also. My trac light wouldn’t go off after I put bilsteins on. For some reason sometimes the vehicle thinks it’s not equipped with downhill assist/crawl control when it is.
