I would like to make one of the positive pressure brake bleeders using an extra brake cap attached to an air regulator/compressor. I bought the cap, but am not for sure where I should put the air. The cap has two o-rings, one at the very top, and one at the bottom on the end of a plastic stud. There is a hole in this stud between the top and bottom o-ring, but the stud/tube is capped when it gets to the bottom o-ring. Should I put the air into this tube, pressurizing the area between the two o-rings, or should I extend it down to the area below the second o-ring? I've seen some of the units sold specifically for this, and it looks like they just pressurize the whole thing, but I don't want to damage anything.
I was only going to use 2-3 lbs of pressure.
