Brake Hose Recommendations?
Is there any difference between Toyota OEM brake hose or aftermarket brake hose? Is it extra price on the Toyota OEM brake hose worth the price?
Correct. The banjo fitting on the 4runner, Tacoma, and Tundra are all the same. These are the lines that I used when I did my TBU upgrade. You'll have to bend the little metal bracket on them to be able to use the factory mounting hole on the spindle.
I'm going to do a little work tonight on my 4runner, and I'll see if I can grab a picture of what I did.
The link referenced is dead, but Wheelers still has a 95-04 Tacoma extended brake line set that includes 2 front and 1 rear, all 22.5" long
I stuck with factory length front and extended in the rear
Rubber vs SS braided, otherwise no. YMMV
Tx470
