Brake Issues
HunterG425
Hey y’all,
I’ve been having some issues with my brakes. Occasionally my brake pedal gets “hard”. I’ve read that it may be the brake booster, but my issue is slightly different that others. It usually only happens after I brake for a short period of time and try to re-apply the brakes; usually in parking lots and such. If I press down hard, the brakes apply and work normally. Would it be the booster or something else?
Thanks!
Did you check the one way valve located at the booster? It is the one that holds the rubber hose. There is a rubber grommet as well. YOu can buy both OEm from the dealer or partsouq.com (3 day shipping from UAE)
AndiGarage
