Brake Pad upgrade? (stocks suck imo)
any of you guys upgrade your pads? if so what have you gone with?
i just feel like the stock pads on my Pro dont have that great of bite ya know. im sure some of you guys have felt the same way. just wanted to know what some of recommend for swapping them out for
How old is the car? Even on my sisters new forester the brake pedal was absoute shit until we serviced the brakes.
I'd make sure they are freely moving first. which means cleaning no rust on the brake/caliper mounting points. 1-2 mm of rust can 'grow' on the caliper and cause the pads not to move freely. this is especially important with the rears. Check out any south main auto video on brakes in the rust belt on youtube. he explains it to death.
I had a lot of luck getting a brake fluid flush on my sisters 2014 forester a year after we got it. I complained to SOA in a letter, saying how much of a difference it made, they covered the cost of the flush. they sent me a check for ~165 it cost the dealer to do.
I specifically told the dealer if the pads wearing evenly when I complained about how shitty the foresters brakes were, they said yes. When we changed the pads, I saw they were not wearing evenly. I was so pissed. since the pads were not wearing evenly I had to do the brake job earlier than needed. in any case after the brake job, the pedal was even better than after the brake flush and was rock solid.
my point is you should service your brake system, make sure nothing is binding, no rust, lubed up, and fresh fluid. Then decided if you want to destroy your braking system with aftermarket garbage.
second point, could have thought the stock pads didnt have much bite, but of course it didnt! one pad was doing more work than the other due to the uneven ware
edit: I'd like to add, I did read all over the subaru forums on how crappy the new gen forester pedal was, and people doing random stupid snake oil mods to make it better. I refused to believe that and alter an oem system. dealer really didnt care about subtle details. Did all the small little details outlined by SMA channel youtube, and pedal was so much better!
truck is only a year old 9k miles but its always felt like this from day one, just feels like the stock pads dont have enough bit to them
I went with Brembo pads. I have had them for almost a year I personally like them a lot better than my stock.
Do you have a part number for the Brembos? Also, where did you get them?
I have a set of TRD pads but I haven't gotten around to installing them yet.
Bump
Edit: Used Hawk Pad on all my drift cars. Plenty of bite but some noise (worth it for the bite IMO). Doesn't look like they have a 4runner option tho.
bought a set of ebc yellow with ebc rotors. never installed it. but will do so soon. The brakes are not bad. Just the sensitive ABS system.. i get abs lock so much in wet weather.
I put a set of Akebono Performance pads on mine shortly after bringing it home from the Dealer (PN #ASP976). I wasn't happy with the OEM feel, and these seem to be an improvement.
I think most of the problem with the 4Runner brakes is that it has a weird boost system that bleeds vacuum pressure as you apply force and makes the pedal super soft. This makes that wet shoe squish sound each time you apply the brakes. I personally prefer a more linear pedal with increasing resistance as more stopping power comes on. But Toyota didn't design it that way. they seemed to shoot for a soft even pressure all the way to ABS engagement. Unless you jump on the brakes fast. At which point it goes into panic mode and drops anchor. I am sure changing pads would change the characteristics a bit, and I may do so to increase the higher temp headroom of the system, but I don't think we'll be able to change the pedal feel much given the way the system is designed. I would love to hear otherwise though from folks who have swapped out pads.
I didn't mind stock for a while but with the recent add of 295's and an adventure trailer build underway it's become apparent some improvement is needed.
I've ordered....
Carquest platinum ceramic pads
Stainless lines from Toytec (needed extended rears anyway)
Set of speed bleeders
I used similar pads on my FJ and the stopping power was greatly improved. Hoping for the same this time. I steered away from Hawk due to reports of alot of brake dust but everything else seemed positive. The carquest ceramics from Advance Auto with a 25% online discount coupon came out to about $70 vs $140 for Hawks.
I'll be able to report back after the install this weekend.
Try Akebono performance pads (ASP line). They have a good bite while braking but they produce more dust on the wheels.
I've ordered....
coupon plus rebates if you pair them w/ rotors and so on
I have EBC Extra Duty pads and EBC Ultimax Slotted rotors up front.
Have 20K miles on them. Still a lot of meat on them. They have a unique shim as the shim goes into the piston. You can check them out on autoanything. They squealed at first for the first 100 miles or so. Now quiet. About the same amount of dust as OEM. And when heated up going up and down route 68 in WV experienced no fading. This was one of the reasons I swapped out the OEMs after 18K miles and a few trips to the beach. Didn't like how the truck stopped after they heated up.
Most important. Wife tells me she likes them better than "before" meaning the stock pads and rotors. It's her truck. I just maintain it :)
I've also bled the system twice now (41K miles).
I was thinking about trying TRD pads
I tried to get the TRD performance brake pads when I ordered my 2017 TRD Pro but was told they were not available, anyone have that same experience? Also thought about the TRD radiator cap (literature said it held slightly higher pressure) but I didn't do that, can't remember why.
I have the TRD radiator cap. My reason was because I’m in south Louisiana and it gets hot as balls especially in bad traffic. Figured why not
Bump
Dang I was hoping to throw a set of HAWK pads on the 4runner as I have a set on my Mazda and they are great. Been meaning to see how EBC hold up so now I have a reason to go that route!
seltzernator
