Brake Pad upgrade? (stocks suck imo)
Bump
Edit: Used Hawk Pad on all my drift cars. Plenty of bite but some noise (worth it for the bite IMO). Doesn't look like they have a 4runner option tho.
HAWK Makes an excellent pad, we use them almost exclusively! For the 5th gen 4Runner, I recommend the HAWK LTS for everyday driver and lightly modded rigs (quiet operation), and the SD pads for those who are doing hardcore offroad or those have a lot of gear like a tent or steel bumpers (some cold noise and dust, but excellent bite!!)
Check them out below, use code T4R for discounts!
2010-2019 4Runner Front Pads
LTS - HB490Y.665 - Hawk Truck/SUV Brake LTS Pads
Severe Duty SD - HB490P.665 - Hawk Truck/SUV SD Pads
2010-2019 4Runner Rear Pads
LTS - HB477Y.610 - Hawk Truck/SUV Brake Pads - Battle Born Offroad - The Offroad Part Source!
I tried to get the TRD performance brake pads when I ordered my 2017 TRD Pro but was told they were not available, anyone have that same experience? Also thought about the TRD radiator cap (literature said it held slightly higher pressure) but I didn't do that, can't remember why.
They are the same pads for all models 03-19 (w/ 338mm rotors) - PN PTR09-89111
Oh damn I guess I didn't look very hard lmao. Good news!
Dang I was hoping to throw a set of HAWK pads on the 4runner as I have a set on my Mazda and they are great. Been meaning to see how EBC hold up so now I have a reason to go that route!
They do have hawk pad afterall. My b. Spreading FAKE NEWS!!! REEEEEEEEEEE!!!
They dont list them past 2015 models, but we have confirmed that they work thru current new models. There has been no changes to the pad since 2010.
I was thinking about trying TRD pads
I had put them on mine when I bought mine Fronts were still good. for some reason the rears went out at 14k. less then 10% pad left.
Ordered PowerStop z36 pads and rotors for all 4 (mostly cause i was going to be adding weight - which i have). Stops faster then ever. and they are dustless.
got my stoptech bbk, need to get it installed. hope my 345mm rear rotors clear, if not, time for 18" wheels.
I "upgraded" my pads and rotors all the way around to the EBC yellowstuff brake pads and EBC oem rotor replacements. Worst decision ever. The yellowstuff brake pads squeel SO. DAMN. LOUD. They grooved the rotors out pretty bad. I ended up having the front rotors re-surfaced even though I had only put like 1500 miles on them and then threw out the front EBC pads and put in some OEM toyota pads. Once I have enough funds, I am going to replace the rotors and rear pads back to OEM. Still squeels extremely loud when the brakes are cold. Once warmed up its fine. But I live in a very quiet neighborhood and you can hear the squeel from so damn far away.
You didn't bed them properly..
I ran EBC yellow in my other truck before i sold it. never had squeal. Went through 2 sets of Yellow Stuff on that truck.
Dusty as can be.. But stopping power was awesome. Worked well all seasons here in NYC. No Squeal.
I agree, I switched from a chevy tahoe to a t4r and am very glad I made the switch from a reliability and practicality standpoint. The breaks were much different on the chevy. I drove the tahoe for 14 years so I got reeeeeaaallly used the breaks, and adjusting to the toyota pedal response took some time to get used to. Do break pads change the pedal response at all, or simply add stopping power or shorter stopping distances? I am looking to change pads at the next oil change in about 4k miles and wonder what brand and type to buy? I occasionally tow an aluminum boat that maybe weighs ~700lbs with the trailer, so nothing heavy duty, but still want reliable breaks that will last for a long time. Any of the pads on Amazon worth while?
There is nothing you can to that will add "stopping power" other than tires. The brakes have more than enough friction available to stop all 4 tires from spinning at any time. The limit is the tire's friction with the road surface. You will not improve stopping distance at all.
Different pads and rotors may change the feel of the brake system. Meaning they make more friction with less pressure so it will brake more with less pedal pressure.
They will not stop faster nor will they make it safer. No brake upgrade will improve performance unless you're overheating the brakes until the point of brake fade. More aggressive pads have no benefit in that respect. Only larger rotors that can either act as a larger heat sink, have more surface area to dissipate heat, or be made of materials that operate better at higher temps - like ceramic discs.
Did you reinstall your shim kit?
Super old thread.
I went Akebono, I'll never do anything else. And I have more experience with brakes than I want to remember right now. It was the perfect pad to correct all the shortcomings of the stock pads or other aftermarket pads I tried.
Totally gave the brakes more bite at less pedal pressure which is what the T4R needs so that it brakes like a normal vehicle.
Super old thread.
+1 for Akebono pads. Added bonus is no bedding procedure required.
This is the best answer I've read so far. Sure, I could add caveats and pedantic details, but I'm not going to. It's good enough.
I have used akebono in about 7 of my cars awesome pads
ebc is crap they dust like crazy and don’t last long enough for the price
A bought a set of the Trd pads for the 4Runner but waiting to hit 10k before I change hope they improve on squishy feel:juggle:
Mike
Just wanted to share my experience with Toyota and brake pads. There are some dealers using Toyota brand pads that are NOT stock part number but do fit.
These pads can be identified by the fact they have YZZ in the part number. My local dealer tried to pull the fast one on me with this. The correct OEM part number for my 5th gen front pads is 04465-60320.
When I asked the dealer to install this correct part number, they didn't have them in stock and had to order them!!!!
My guess is the margin is better on these other YZZ pads. I know a toyota mechanic that tried them, and he took them off because they squealed and performed poorly.
My faith in Toyota service has really gone downhill over the years....
albertpeter156
