brake problem.
Do you feel any feedback in the brake pedal when it jerks? Unless you have a surge of brake pressure coming from somewhere, the brakes don't just jerk. Check out the FSM in the sticky. It will tell you how to diagnose brake issues. First things I would check out are your brake master cylinder and your brake booster. If neither of them show any signs of trouble then I would look elsewhere. Do you have an automatic transmission? If so you could have an issue with your tranny.
You might get someone to check the movement on the e-cables when actuated. My guess is, one of them is partially binding or seized in position. It is probably worth pulling the rear drums and inspecting the condition of the brakes.
regards
Southshore
