I've been so frustrated with the aiming issues on my retrofit, so I'm hoping your updated fix solves it. I used TYC housings as well.
UPDATE: Important Gluing Required
Brian, thanks for this thread. I'm following along as I plan out my own retrofit.Thanks! They are great bulbs. I've had them. Now I'm running Phillips in my personal set as well.
I have these Morimoto 5500k in my CT200h and they are pretty great as well. I couldn't include the Phillips in this sale because of the added cost though.
Ah, I thought from your post that you'd switched from the Morimoto's to the Philips bulbs. I'm leaning towards the Morimoto's just for the 5500 spectrum as well, was just curious about what made the Philips stand out.I just like the 5500 color spectrum better. And the Morimoto are great bulbs.
Yes. You assemble everything, check it, then make sure it is properly glued then put the glass back on and the clips then bake it the final time.
Be sure to clean the inside of the glass real well with alcohol swabs and clean cloth that doesn't have any fabric softener residue on it.
Quick question for those of you who have done this--has anyone noticed if their High Beam indicator light stopped working after the retrofit?
I noticed mine isn't working any longer, and while I figure it's probably just burnt out, I thought I'd check here before pulling the cluster out.
Otherwise, retrofit just held up great through a few hundred miles of BC winter nighttime driving. I think the aim is good--only flashed by two oncoming cars, but both times it was at the crest of a hill. (And oddly, both times were by people who were closely tailgating others, so maybe they were just dicks.)
See, that speaks to exactly what was going through my mind: the indicator is failing because the passenger side H4 connector is open.Its not the bulb if it was working before you did the retrofit. I bought this, plugged it into the unused socket and works as normal.
