Buying an '86
VonMussa
Anything specific I should look at? There is minimal rust, minimal oil leak. Seller states the 4x4 and clutch work great. Rear window doesnt work.
The back end seems to have a bit of a sag to it. Anything I should be worried about? Or is that something a lil leveling kit will fix?
Any suggestions would be appreciated.
test out the 4x4 before you buy it, i bought and 86 with a little bit of body rust for 1200$, AC doesnt work(yet), and mine had a sag in the back, leaf springs were good, shocks were good, i put a 2 inch block lift in the rear and it took care of the sag
Depending on your location, rust could be a serious issue. Toyota's are infamous for frame rust. It's not always readily noticeable, as it rusts from the inside out. You don't notice it until it's bad.
New springs will fix the rear end sag (another common problem).
