Bypass radiotor instead of replacing?
Boudin
Just wondering on everyones input. 99 with 144k miles, original radiator. Was trying to replace it but after buying and returning 4 of them for broken overflow nipples and crushed cores I'm ready to give up on getting a good one and just bypass the trans cooler to an external one. The stock radiator isn't leaking and I did a couple flushes to clean it up. I should be OK as long as I bypass the trans cooler right?
Sent from my SM-G965U using Tapatalk
I bypassed my radiator with a Hayden 678 trans cooler with great results so far but on my 01 I don't do heavy duty 4 wheeling. I did pull a mountain dirt road during a 90 deg day and saw the trans cooler temp (Ultragauge) get up to 204. It normally runs in the 150-165 deg range.
I'd definitely replace the radiator anyway when you can. I recently replaced an engine because the upper hose blew off the radiator. Not sure why you're getting damaged parts. Have tried ordering from Amazon? I got this one in great shape shipped to my place.
PS: If you live in cold country; it sucks to have to do emergency repairs in the Winter. Also; nice looking rig! I might be a little biased. ;)
Did you purchase from Rock Auto Denso?
The after market sadly seems to suck for radiators especially the chain auto parts stores. :[
You can bypass like others have suggested. However, nothing would stop a hole from developing and loosing all your coolant through the empty trans cooler tube.
Liquid to Liquid heat transfer is extremely efficient. Where air to liquid isnt as efficient However, lots of folks bypass. I just replace radiators every 10 years to prevent the milkshake. ;)
I just bypassed mine about 6+ years ago. I capped radiator ends so if a hole does happen it will stay in the radiator.
The main downside I can see is on very cold mornings the transmission is slow to warm up without the engine coolant to help but its been working fine so far. 240k miles on original motor/tranny.
Yea I do really want to replace radiator but tired of returning one after another. All from Amazon, 2 Spectre, 1 Mishimoto, 1 Denso. I thought about just getting a Denso from the dealership. There all the same exact radiator, just rebranded I assume.
I live in the southeast, don't do any towing or offroading, that's why I'm tempted just to do the bypass.
3 years ago all other components were replaced, water pump, thermostat and upper/lower hoses.
Bypass is fine in your situation.
I bypassed mine and I live in Houston and don't tow and the tranny has never seen over 170.
Just cap or connect tranny nipples on the radiator together. Do pay attention to the age of the radiator, though. If the top is brown and seems brittle, replace it anyways.
I got my radiator from a seller on eBay (when my top split) and he had it shipped to my porch that night (seriously) and it was in perfect condition.
I'd worry just as much about the plastic tanks leaking/cracking as much as a pink milkshake. If the top tank is turning brown, it should be replaced - whether or not you get a trans cooler. I even opened up my original radiator when I replaced it a few years back to check for corrosion - my trans cooler was still in perfect shape in the bottom tank (no rust or anything).
Try ordering from RockAuto, I think the put a second box around radiators when they send them out...
-Charlie
Radiator is something you'll replace once every decade or so, so I would bite the bullet and get it from the dealer or a place like Camelback Toyota. If you order online, you can write in comments section to the seller to pack it really good so there is no damage to the product, pointing out the nipple issue you've had in the past. BTW, when i replaced mine, it was still the OEM with 233K miles on it. So long as there is no corrosion and it's been maintained regularly, flushed every 30K for example, it should be in good shape. But then again, it IS 20 years old, so I would replace it for peace of mind and as a preventative maintenance.
I added a trans cooler in series for added cooling capacity. The B&M 70264 will mount up using the parts in the kit using stock mounting holes, but you'll have to relocate one of the horns.
I ordered a replacement radiator on Amazon, and it came kind of beat up. Maybe try a local parts store, not sure how many carry Denso.
Ordering a radiator online seems to be hit or miss as I purchased a Denso from Amazon a few months back and received it at my door in 2 days with zero issues......not even a single bent fin!
You may want to take a look at Timmy the Toolmans video on adding a trans cooler as I found it really helpful.
The dealer sells the same Chinese made POS you would buy at autozone. You can buy an legitimate OEM for $600 shipped from Partsouq, at that money you could have a Koyo aluminum with an external cooler! But maybe $600 is a steal since it lasts 20 years when maintained.
I wouldn’t bypass as your quick-to-warm ATF plays a vital role in bringing coolant temps up ASAP upon cold start.
Does it really? Both take more time than you'd think to warm up. Even with driving around for twenty minutes on a cold winter day the coolant will be lukewarm at best. I would think the coolant warms up the ATF faster and then maintains the temps.
Right on, when I replaced mine I went with Koyorad from Amazon and I guess got lucky that it wasn't damaged during shipping. It's been going strong for 30K so far and I've already flushed the coolant once, at 15K miles. I also have an inline trans cooler, I opted to NOT bypass, since the rad is new.
In the winter, with the inline trans cooler, my trans consistently runs at 120F and i haven't had any issues, at all. A cool trans is a happy trans. I bet a trans running cooler than "normal" will last longer than one that's running hotter than normal. AFAIK, high temp is the #1 killer of transmissions and I've never heard of transmissions issues because they ran too cool. But hey, what do I know... :)
I'm thinking you have a regular plastic tank Koyo. I'm speaking of the all aluminum they just released this year. Only downside is that they didn't include the trans cooler so bypass in mandatory.
Yeah, I honestly see no problem with the factory cooler when not towing. Agreed better cooler than hotter.
So I was in the same camp as you. My trans cooler actually came out of a 5.9 cummins from a junk yard ($18 if I remember correctly) and I ran just that cooler for close to 8+ years and never had a problem. it would sit at 140* in 85* ambient and spike to 160 if I got on it. Last winter I was driving through a -2*F section of road and my trans temp cooled off to 90*F after driving from Sacramento to Tahoe up hwy 80, it had 1.5hr to get to full operating temp.
That was too cold in my book. I installed that oil thermostat and its been great. Cruising on the hwy I sit at 159* as long as its not 100*+ outside then will spike to 185 if I jump on it to pass someone or climb a long grade with the torque converter unlocked. I did a quick cool down time using my scan gauge and a stopwatch in my head. The scan gauge will report 185* and cool back down to 165* is about 7s, having excess cooling is a great thing!
I doubt it was the only reason but noticed a pretty significant mpg gain but I do not know if that was related to something else, who knows.
I do agree with you, it is better to have a cold trans than hot, but I also think there is a better way to control the temperature rather just let it get as cold as possible.
I got an OEM one from my local toyota dealership for $200.
charlesz
