Bypass radiotor instead of replacing?
The manual 4 runners don't need a trans cooler..:D(
My manual trans Camry with Celica GT4 drivetrain has a transmission cooler! (it has an oil pump, cooling loop and squirters for the synchros - all OEM Toyota)
So, not *all* manual transmissions have no oil cooler :smokin:
-Charlie
-Charlie
That's interesting. Is it a mechanical pump? I looked up R series transmission coolers and many seem to use an electric pump.
-Charlie
Correct some do..Hence why I stated manual 4 runner 3rd gens..:D
Wouldn't your Camry and Celica have trans axles too which would be a transmission and differential combinations.
I was never fortunate enough to have a standard camry. I have however had an engine and transmission out of a 90 Camry swapped and done with using a tree in the yard..:D However it was an auto.:D
Yeah, mechanical gerotor style driven off the center differential. It only pumps while the car is moving.
Yeah, transaxle - with 5 forward gears, two differentials (front and center), rear angle drive *and* a viscous coupling unit all sharing the same lube. Lots of heat as manual transmission go, and it was a rally homologation drivetrain, so lots of extra 'bits' are included that wouldn't normally be needed on a street car.
-Charlie
-Charlie
It would have to be with all that going on. Its more of a hybrid fluid with one cooling system then separate components
The 2 downsides i see from this type of setup is:
1) contamination destroys everything
2) more seals more chances of developing a leak and with a system like that.
:snacker:
youngrk
