DannyLlama
Elite Member
About to pull the trigger on cooper A/T3
I see they have a C load but it's $60 more a tire. Is it worth it?
Both are 275/65/18
Both are 275/65/18
Both are 275/65/18
What is a difference in a tire weight?
I would say yes. It depends on how you are going to use them I guess.
But personally in my eyes the 5th Gen 4Runner deserves at least a C.
Did you go with a C rated tire?
Sweet rig btw!!! is it lifted?? You digging the tires? Or are the Tires digging!! < WIIISE GUY
http://www.toyota-4runner.org/5th-gen-t4rs/113734-tire-load-rating-question.html
Read the above link.
If you are going to pull a heavy trailer a lot or are going to be off road a lot get the C rated tires. Don't stop there get the E rated tires.
If you are going to be like most and be on road a lot with little off road get the P rated as they will perform just fine. I go off road a lot and got the P rated. I go in dirt and muddy conditions not so much rock crawl though. I have owned P, C and E several times in the past and have returned to P as they are less expensive initially and wear just as long and lose very little mpg vs. stock due to weight. If I were in rocky conditions a lot I would get the C or E and that is the only reason.
More than the off road capability. Having more ply in the tire will preform noticeably better on road with slightly less roll resistance. At least that's what the tire shop guy said, unless I'm being ripped off lol < nothing new.
Here are the weights of the A/T3 for 17" wheels as provided to me directly from Cooper last week in case anyone is interested:
The Lt275/70R17 (E), (C), and Lt285/70R17 (E) Cooper Discoverer A/T3 tires should weigh the following listed weights:
LT275/70R17 E A/T3 spec 5875 weighs 51.88 pounds
LT285/70R17 E A/T3 spec 5850 weighs 55.17 pounds
LT275/70R17 C A/T3 spec 5871 weighs 50.70 pounds
Interesting that the E only adds a pound over the C in the 275. FYI, I also checked the bad ass S/T Maxx in a 285 E, and was told it weighs a whopping 60 pounds. With its sidewall reinforcement I would have a lot more confidence in it over the 285 DuraTrac off road, but it is 7lbs. heavier.
edit: nevermind I just realized you listed a different size than what was being discussed....
I agree the ST MAXX looks like an awesome tire!
