Cabin Air Filter - which one is the best
AlexJet
I'm about the change the Cabin Air Filter. I did allot of search on the forums and Web, but couldn't find any reasonable compare or recommendation which one is the best. Each manufacture claims it has the "deal". Have anyone tried any of the following and know which one is better?
Looking for Carbon Premium filter
OEM Toyota 87139-YZZ10 - $45.50 (local dealership price)
9c3dc7c77db83a8e4051cea413970a07.1500
FRAM FreshBreeze CF10285 - $33.62 (local price)
WIX 24511 - $25.23 (local price)
imageuploadedbytapatalk1365569124-737046-jpg.49507
ATP Carbon Activated RA-31 - $26.22 (local price)
MAHL Original LAK 490 - $29.02 (local price)
TYC 800108C - $21.82 (local price)
The absolute best one will be OEM Lexus 87139-50100 which fits the 4R. It has activated charcoal to reduce odors. I use this in my car with great results.
Its nearly 3x more expensive then others - $61.57
Right, but it is also the best. I buy mine on eBay through reputable Toyota/Lexus dealers only. They are usually between US$35-45 on eBay. Do not buy from non-dealers on eBay as they are usually fake.
When I got my new-to-me 2011 Limited back in 2016 the previous owner had a Toyota cabin air filter (and it was pretty dirty!).
I compared the dealership price with aftermarket, and decided to install the WIX 24483 Cabin Air Filter $29.20 CAN (2016 price). It had the Bioshield 75 biostatic surface protectant. This is a particulate filter (not the 24511 carbon filter you have in your original post)
A year later, upon removing the WIX, I installed the CARQUEST 90146C Filter $12.87 CAN (2017 price). It is a premium filter with charcoal.
Carquest Filters - Air
CARQUEST - Part Information
I'm just about due for a new one, and will be going back to CARQUEST. The quality of this filter is very good, and you can't beat that price!
Anything with activated charcoal will be good.
Charcoal filters may be good in warm weather climates but not for cold. I discovered if the charcoal filter was cold, <10*F (<-12*C) and then you went into a car wash with humid air that the filter became wet, plugged it up then horrible fogged up the windows on the interior. This only ever happened with the charcoal filters. I submitted this review onto Amazon.
Like the engine filter, it is best to wash and reuse a filter. I also have a washable K&N cabin filter.
“Best” has different meanings to everyone. Based on info I’ve seen elsewhere, reusable engine air filters generally provide more air flow at the expense of allowing more particulates into the engine. I haven’t seen any info like that specific to cabin air filters but for about $30 plus <5 minutes of time annually I’ll replace the cabin filter.
I believe the simple solution to that is to turn on recirculation mode before entering the car wash. I wouldn't want to breathe all those atomized chemicals in my truck!
If you're trying to keep your windows from fogging inside, you've got to keep your interior humidity down so there's no moisture to condense on the cold glass. Allowing warmer and very humid air into your vehicle is a sure way to fog the windows when you drive back into the cold, charcoal or not. The filter will absorb some of the moisture then have to dry out which means a time with that elevated interior humidity level and fogged windows. Since charcoal is a very absorbent material, I assume that it's retaining more of that moisture and therefore takes longer to dry, again adding more time of elevated humidity inside the vehicle.
On older vehicles you could run the A/C on a warm temperature to help keep the truck warm while removing the moisture. Because cold air holds less moisture it is more effective at clearing the condensate (fog) from the inside windows. Which is why most modern automatic climate controls blow cold air through the defroster. I'm not a fan of this because you end up with a repeating battle to clear the condensate. Blowing warm dry air on the glass works in two ways to clear condensate, carrying moist air away from the glass, and warming the glass to the point where condensate won't form. So if you're really having trouble with repeated fogging, hit the wiper warmers (raises glass temperature), and run the A/C with a warm temperature selected.
Unfortunately most automatic defrost modes also force recirculation mode off, enabling colder outside air inside the vehicle. When it's 15F or so there's not really any moisture in the air, so that's not a problem. When it's warmer, say 35F and rain/snow mix, you're going to have a big problem with condensation on the interior glass because of the amount of moisture entering the vehicle. You're actually better on days like that (and humid car washes) to leave the recirculation mode on, defrost off, but the A/C on with a warm temperature. Most auto HVAC closes off different baffles depending on the temperature setting. So selecting full cold, draws no warm air from the heater coil through the vents. Similarly full hot, doesn't draw any air through the a/c evaporator, which you need to help dry out the air in the vehicle. Warm air will draw from both, enabling a warm dry air for the vehicle. If you have the dual zone or automatic climate controls you're stuck, not much you can do aside from add the wiper warmers to increase the glass temperature. But the simple climate controls will allow for the combo of warm A/C air with recirculation on provided you're not in the defroster mode. You can select the split defrost/foot mode and then re-enable recirculation.
As for which filter is "the best," that's pretty subjective. Best can mean cheapest for many, best smelling, most effective at removing particulates, or removing fart smells.... best how!? Personally I use the Wix Charcoal Filters #24511.
The original OEM cabin filter in my TE had a pre-filter pad on top of the pleated filter part. I was disappointed when none of the after market filters had this. I may spring for another OEM when it's time to replace my Fram filter. Not sure about the K&N with the oil for cabin air.
I got the bosch 6055C. It reduces the sir flow so at first I did not like it, but my wife loves it as she thought the low speed was still too much, and she did not want to mess with the vents all of the time. As far as air quality, do not know, I live in Miami and it is pretty clean as it is, I can tell no noticeable difference between it and the original.
