cadillac air suspension system question...
delgadog
i read something on yota-tech about using a cadillacs air suspension pump in conjuction with a 1-3 gal air tank for use to fill up tires and tools. are there threads that talk about that here? i don't know what to search for here, maybe someone can help me refine my search wording i guess. or if anyone has a link to a build thread and what year cadi's that would be awesome. thinking about doing this instead of buying an after market air system. thank you!!
I used to use a Caddy compressor on my old truck. I'm not a fan of 12v compressors as they are a bit slow, run hot and pull a ton of amps. On the plus side they are cheap. Because of the low output I ran two pumps to fill a couple gallon tank. The tank didn't add too much of a benefit even with airing up but I had the space.
I'm not sure of the year model I had but they were used on many models for many years. The type I had had the built in air dryer which is a small black tank looking thing. I'm having trouble linking url's but google images is showing the type I had on eBay ads.
Interesting enough I bought my compressors for around $10 a piece and sold both for $100 on eBay, about 10 years ago.
wow, thanks for the info. yea, i was reading a bit about them, thought that would be a cool cheap mod to do. i've read they run hot and takes a bit of time to do it, but i'd only really plan on using the set up to air up tires and that shouldn't be often, at least i hope.lol. thanks again for the info.
Have you looked into converting your AC, or using a York compressor?
York FTW
My install: http://www.ultimateyota.com/showthread.php?5324-York-for-the-3-4-liter
kid v, i need a/c.... i'm in florida...lol how does that thing work 4x4mike? and how much does it cost? lol and i wouldn't even know where to begin on converting the a/c compressor, tho it is a good idea!
That York is an AC compressor but from a different vehicle. It works just like a shop compressor, a motor turning a compressor (which intakes air, compresses it then discharges it). In this case the motor is the 4Runner motor and the compressor is the York. Yorks are popular because they are plentiful, can be had for cheap, can be mounted on their side, have a sealed oil crank case and they have high output.
It's hooked up to a pressure switch, just like an AC compressor. When the pressure is below a set pressure the clutch engages and the compressor starts sucking in air and compressing it, sending it through my system. When the high side set pressure is achieved the clutch disengages and the compressor stops sucking in air.
It's all pretty easy as the compressor does the work. I bought a kit but they aren't made any more. It would be easy to make. A bracket, combo pulley to add an additional belt, switch, pressure switch and fittings/air lines. For as simple as it is it can be pretty expensive. I'd say it could be done for less than $100 if you had some scrap metal, know how and good imagination. Mine was more :bigok:
Is your AC broken or do you just not have it? What vehicle is this in? If it was a factory option you can get the compressor that is supposed to go on the bracket you most likely have. The compressor has in and out ports. Basically you need to put a filter on the intake and a hose on the discharge.
Without freon (oil) the compressor will not like life and die quickly. You'll need to find a way to keep the compressor oiled and the discharged air filtered (take that oil out and send it back to the compressor).
Put power to the clutch through a pressure switch and feed a tank or hose with a coupler on the end. I prefer the York option as it's easier in some respects.
Now, see, if you didn't have one of those inferior second gen trucks, you could just take the top off and not have to worry about it. :moon:
I've seen a couple writeups with a York and a factory AC pump on the same belt. I think they were on 22RE motors, but maybe you could find room?
I have a/c, i meant that i need a/c because i live in florida and its hot as everyone knows.lol. now, if there was a way to keep the a/c compressor and do this somehow i'm all for it. thats really slick tho, looks factory, i like it. you guys are some awesome fabricators and damn smart. i appreciate the info! i just read about the cadillac compressors and it got me thinking and was wondering about it. inferior 2nd gens? lol i believe the BEST gens were 2nd gens, i'm just saying....lol
don't hate because you can't handle a 2nd gen, must be to much for you.lol. its my first 4runner and i love the lines of a 2nd gen and the ruggedness, more so than the 3rd gen. 4runners are bad ass in general :)
