Calculator: How Tire Size Affects Speedometer Accuracy
Seems off to me in the rpm department. Even with 4.56 gears I'm only around 2000 rpm at 65 on the speedometer which I know I'm going a little faster.
revolutions per MILE is for the tire - completely separate from the engine speed (revolutions per minute)
At the bottom(where it says gear ratios / RPM @ 65mph), those are engine RPM values and they seem 500-600RPM too high to me, at least with my stock gearing and 285's at 65mph.
Just use a gps to get the accurate speed and compare that to your speedometer.
did you factor in overdrive transmission ratio?
I always liked the calculators on the following site (calculator links are at top of left nav bar).
4LO.COM :: On-Line Gear/Tire Size Calculators
How did this thread go from Speedometer reading accuracy to Tire Fitment? Nice Hijack... :confused: HAHA!
Because the link you posted and are discussing is in my post and the speedo differences are too. Reading comprehension is not one of your strong suits I see.
What he meant is, make your spreadsheet more interactive so we can just plug in the numbers and it will spit out the actual speed difference automatically.
What do you expect us to do with the % differences you listed in your spreadsheet for every conceivable tire size specific to our 4runner? calculate by hand?!?! :crazy:
actually, my post had nothing to do with tire fitment and was in response to questions (in this thread) around engine RPM's due to tire size change. calculators in my link are also for gear changes, speedo, etc.
My bad. I should have known how hard it is to multiply a number by one point sumthin'.
