Calling all k02 owners 265 vs 275 ?
Have you got a nice side profile pic of that setup, from a medium distance?
http://uploads.tapatalk-cdn.com/20161109/8fcb8b2b673fae59fc16b1411e38dc58.jpg
Thanks for that. Those look so much better than the OE tires in the same size. It's definitely helping make up my mind... can't do everything I want in the same year (new truck, new wheels, new tires, new suspension, new bumper/winch, etc) so having to pick and choose what goes on at each stage... seeing how good the stock size looks with properly aggressive tires means I can forget about a lift in the short term and do other things.
Cheers.
Cheers.
I ended up sticking with the 265 (C rated) size for a couple reasons.
I had no direct experience to compare the ride difference between C and E rated tires. So, going with the Cs was the safe choice plus off road ventures will likely be confined to fire roads.
Because I will be doing so much city driving for the next couple years, I wanted to minimize any effect on mileage due to the heavier 275s.
Once installed, I was really happy with how the 265s looked. Much different to me in person versus seeing countless photos. I am very pleased with the ride quality, too.
after reading this thread, has anyone taken the time to measure how tall and wide your tires actually are, mounted on the vehicle?
I'm curious in the actual difference between the c-rated 265 and the E rated 275. I know what BFG claims the measurements are, but mounted measurements are usually .5-1" smaller.
Point of reference, teh stock Dunlops (mine have 2500 miles) measure right around 30.5" tall on the vehicle, and closer to 31" when not on the vehicle (still on the rim).
I have 275/70/17 KO2s Load range E with a few hundred miles, mounted on stock Trail Edition rims. While on the 4Runner they measure out to be 31.9 tall and 9 inches wide of actual contact tread; including the gnarly sidewalls brings it closer to 10 inches wide.
I have 275/75/70 KO2s Load range E with a few hundred miles, mounted on stock Trail Edition rims. While on the 4Runner they measure out to be 31.9 tall and 9 inches wide of actual contact tread; including the gnarly sidewalls brings it closer to 10 inches wide.
Perfect. Thanks for giving me some perspective.
Based on my experience with 275/70R17 currently on a non-lifted vehicle, I'll say that they look really good and fill out the wheel well nicely. The E-load is noticeably heavier than the stock Dunlops, and I've had to re-balance about every 5000 miles so far. 99% of my driving is on road (I take fire roads to remote hikes frequently), but I think when these wear out I'll probably go back to the 265/70R17 for some weight savings.
They now make the KO2 in a 255/75. Getting them on my truck this month. Bfg has a mail in rebate through 11/27
With the right (wide) wheels, 265's will look beefy enough and you get the benefit of the light weight C load
044runner4
