Can 5th gen wheels work on my 4th gen 4 runner
3 of my 4th gen sensors are bad but the new wheels and tires from the 2018 are coming with the sensors. Would you know if the 5th gen sensors are compatible with our 4th gen? Would they work?
Got ya. Sorry, I don't know the answer on the 5th gen sensors.
I'm still flirting with the idea of getting a set of TE (now TRD Trail or whatever) wheels too. I'm really hoping to get rid of my Spidertrax and not have issues with my 285/70 Duratracs but it sounds like there's no consensus and I'll only know once I get them.
Anyway, what's a good price for these wheels anyway? There's a take-off set for $575 on CL here, but I was thinking maybe a slightly used set would go for $400 or so?
I paid $500 in Denver for brand new take offs, $575 isn’t a bad deal. My 285 KO2s fit without rubbing (without wheel spacers)after I pushed the wheel liner forward and slight trimming on the lower edge of the front bumper.
Also plenty of UCA clearance, at least with LR SPC upper arms
I'm going to buy a set of 2019 4Runner TRD Off-Road Premium today with 75 miles on P265/70R17 Dunlop AT20 Grandtrek. Wish me luck.
2012 FJ wheels with skinny tires
I went skinny with 255/75/17 on my FJ Takeoffs. I like these as they are not as common. The only lift I have with mine is FJ Trail suspension swap. So with the skinny tires and suspension swap, I have only about a 1 inch lift, give or take.
No Rubbing at all. I might go bigger after these Jeep tire takeoffs wears out but if too big and the 4Runner is too tall, I'll have a hard time loading my kayaks.
I got these for $600 and I almost feel like I stole them. I still have tread left on my stock wheels so I haven't put them on yet. Should I expect and rubbing on the front or rear?
Awesome place to ask a same question
Hi, my 4th gen TPMS light just begins to flash. I am thinking it might be time to change the sensors. I run into a deal for a set of 5th gen rims for $200. I am thinking to swap my tires to the new rims. Does anyone know if the 5th TPMS sensor will be programmed to the 4th gen? Thanks in advance!
did you check to make sure if the TPMS light is not coming from your spare? after I took the weights off the spare, it holds air better and my TPMS light is off. The weights on the spare rusts and causes the air to leak.
about the reprograming, I would assume so but never done it. good luck
It'll fit exactly the same as your stock set up, same dimensions.
Sent from my Pixel 3a using Tapatalk
Thx for quick reply. I'm trying to pick up a set of wheels today, with P265/70R17 tires and put them on a 2005 stock 4Runner. I understand the wheels have a 15mm offset difference and I'm wondering if these will fit without modification. Do you think these will fit without rubbing?
Thx for your reply.
Pat
Thx for your reply.
Pat
I have early 5th gen trail wheels on mine, but they're also +15 offset with 265/70r17 tires. Stock is actually 265/65r17 on +30 wheels, but the 265/70r17s are only 1" diameter larger and fit fine on stock suspension. Speedometer with read 3.14% under actual speed due to the larger tires, but its not really an issue. Mine only rub when combining brake and tight turn (like u turning while slowing down from 45mph) or reversing and turning in side sloped scenario
Thanks for the timely info! I'll get the rims/tires and let you know how it goes.
Pat
Pat
Sounds good dude! There are also some simple mods to get the tire not to rub the fender liner at all with 265/70s, I just haven't gotten around to it yet lol.
Sorry for nitpicking, but although the diameter difference is 3.3% the speedo difference would be less than 2% (considering it was reading higher to begin with the difference is less that negligible)
Have the same rims -- love this style.
Gotcha, I was just assuming circ_small=pi*dia_small and the bigger size was circ_big=pi*dia_big and the speedometer scaled off circ_big/circ_small. I have noticed on worn 265/65s the speedo read slightly under, so it makes since about a negligible difference. For curiosity sake, where can/how can I calculate how much the speedo is off by?
I agree, I really like them too. I actually have bookmarked a few of your posts since I like your setup haha.
Hey, to be honest I havent dont math, I have used the web site:
Tire Size Comparison
It has proven to be fairly accurate in its assesment when I compared my speedo to a GPS.
PS thanks! nothing special about my build tho, but I am glad you liked it.
7ron
