Cant find the fuel leak on 1995
Ok , Im new with the 4 runners so I need all the help I can get, my daughter has a 1995 that is leaking fuel from the rear of the engine area. I am going over to look at it (since she can seem to get the idea that you lay under the truck and follow the fuel line). Any suggestions for the most common areas to have leaks on this model?
sounds like the fuel pulsation dampner located on the back of the fuel rail at the back of the engine . there is a small screw that falls out and you have a leak . don`t drive it! it can catch fire if it gets on the exhaust .and you will need to remove the top half of the intake manifold to replace it if that is the problem.
hope this helps
RennSport2UZ
