can't get bolt loose!
tacozappy
I'm trying to install a Ironman lift kit but i'm having trouble getting the bolt that connects the brake cable to the strut off,i've tried a wrench a with extension but it wont budge starting to scrape those threads off. So any help would be great, not trying to look for anything to expensive.
Also if you dont mind, check my website out called japanautotune
Brake cable to strut? Just take off the 3 top bolts and the lower one. You don't need to mess with brake lines. However PB blaster, liquid wrench, impact gun, or the torch will help remove a stuck bolt.
The best for removing any stuck bolt is 1 part brake fluid to 1 part acetone. Even WD40 would be jealous...
