cargo net confusion
digphisher
I recently purchased a 2005 SE, and it came with a cargo net. The net has 2 hooks, on two corners, and elastic loops on the other two corners. I've seen it setup 2 ways so far: one with it flat and hooked onto the floor at all 4 corners, and second with it vertical. I can't seem to figure this stupid little net out. Can someone help me?
There are 2 types of nets -- the spider net goes over teh double-decker cargo shelf, and the envelope net attaches vertically at the rear of the cargo compartment.
The spider net lays flat, has two plastic hooks on one end and four or five loops on the other end to attach to the small hooks on the underside of the double-decker.
The envelope net has two plastic hooks to attach to the rings at the rear of the cargo area and two loops to go over the knobs on the sides of the compartment. The net also has a the sides "sealed" to form the envelope.
Does that clarify?
Thank you so much. I had no idea that there were hooks under the double decker cargo system. Finally it is figured out! Thanks!
Clocktower07
