cbielat's 2011 SR5 Build Thread
Sweet build!
Does the cbi rear bumper have a dedicated hi lift jacking point? I do not see one. I would think there should be one since these bumpers are made for it. Or I think they are.
Sweet build!
Thanks man. No, there isn't. I have been thinking about cutting out two spots for one. It is a nice feature and piece of mind.
Couple more pictures of the front bumper. Began taking the solenoid off of the winch.
I like the design of the hoop on yours vs. the one I remember from their photos. I think it was a flat piece of steel that protruded out a little bit. This looks really nice. Excited to see it on your vehicle.
Yeah, I wasn't a fan of that design so I told them I wanted the traditional single hoop with just dom tubing.
Thanks for the reply. I would of thought this would be standard on a aftermarket steel bumper. I'm surprised it doesnt have one. My arb bumper has two slots for a dedicated hi lift point.
I'm going to request CBI to do this for me and reinforce that area so it can be made to lift the entire rear end if needed with a hi lift.
It's after 8pm eastern, impatiently waiting for those sexy photos to get posted. When my truck grows up it wants to be like yours.... :madgrin:
3/20/16 Front Bumper and Winch Installed
Big thanks to my friend Alex for his help with this.
First we took off the front bumper cover and installed the winch and led markers/signals. Took the solenoid off and apart. Using the relocation kit, we moved the solenoid to the engine compartment which is what Alex is working on in the picture. Then we installed the bumper.
Bumper Install
Once the bumper was installed, with the stock cover off, we cut it across with enough room for adjustment. There are no install instructions or measurements. Just a bag of nuts and bolts and two fog light brackets. It's pretty straight forward though. Once we had the cover cut, we took our time getting as precise of a fit as possible. Left the corners attached to the grill. It worked out great. Used a cut off wheel for the cuts to the bumper and then sanded it down on a table sander. We used a soft/fine grit paper. We went back and forth on this about 6 times making sure it was right. Not sure if I was supposed to get rid of the metal bottom grill mount but we did. Cut out a section so I could reach down to get to the winch engage/disengage lever. It's a difficult angle to lift up on the lever but doable do to the placement on this winch inside this bumper. I decided this would be a good idea if needed.
Bumper Install Continued
With the bumper on, we then spooled up the winch. Need to figure out which lights to put into the bumper.
That's hot.
The cutout inside is for the winch? When cutting the stock bumper do you just leave it rough or use stripping like the rear? I assume it weighs 130-150lbs? Any other surprises?
Edit: Just saw your follow up to add description so I'm sure you'll hit all this. Still so hot...
D'Angelo
