Cement Grey Daily Driven TRD Pro (mild) Build
Do you feel with this additional weight and the 2" lift you installed, the ride is comparable to the stock suspension? In other words, is the ride on the highway comfortable and not stiff?
I have not noticed any degrading to the ride quality. To my standard, it rides fantastic.
delaWeb your vehicle is flawless!!! Giving me all sorts of regret for not being more patient and waiting for a cement TRD Pro to become available around me..
Loving your light set up up front all around. What headlight/fogs are those? Did you get the entire lighting kit from Aiden James Customs or only the DRL fog light bezels?
I think on any other color all that yellow / amber up front would be horrible, but it looks phenomenal on the cement!
I like what you've done to your truck. I'm in the process of doing almost the identical mods to my 4R. My C4 bumper is due next month. After I get it installed, I want to install the 2" TRD Pro lift from Toytech like you have done to your front. I estimate the added weight (C4 bumper 75lbs, winch 75lbs) to be around 150lbs.
Do you feel with this additional weight and the 2" lift you installed, the ride is comparable to the stock suspension? In other words, is the ride on the highway comfortable and not stiff? I have this fear that when you compress the spring to give it lift, you're also removing some of the latitude the spring needs to keep the ride comfortable. What I want to avoid is a stiff suspension that feels every bump in the road.
Gorgeous truck! I would be more concerned about off-road suspension performance with adding a 2" spacer on stock springs that are already super soft and weighed down with 150lbs hanging off the nose.
I think the 2" Toytec spacer was perfect to compensate for the added weight of the super heavy bumper.
Sent from my Pixel 2 using Tapatalk[/QUO
NICE TRUCK!!
I may have missed it,
What winch are you running?
Thank you for the info, beautiful truck!
Cheers!
Amazing build so far! What's next?! Also, what winch did you order for that bumper??
I'm running the Smittybilt XRC-9.5 Comp Gen2 Waterproof Winch with Synthetic Rope.
As far as what's next I'm pretty sure it may end up being a hardshell rooftop tent. But that's not for certain as I'm not sure I can benefit from it much as living in Miami is a blessing but a curse in that the closest decent campaing / offroading spot is 4 hours away.
Haven't posted around here in a while. Here are some pics from a trip I took a couple weeks back to Ocala National Forest.
