Changing Pre-cat O2 sensor
War Sprout
Just wanted to make a note to all of you on here doing this, as I just did mine and I noticed something that was wrong in the write-up.
O2 Sensor write-up
First off, things that might be helpful to know is the connector bracket can be removed with a 10 mm socket, and I used a crescent wrench on the 2 nuts on the sensor.
But what is most important is that you do not need to use a small screwdriver to disconnect the harness. There is a tab on the back side that you can press down to release it. Using a small screwdriver for me was ineffective, and its a good way to get some bloody knuckles and screw up your harness.
Have a nice day!
AlaskaRuss
