Great read, and I learned a lot about offset, backspacing, and general tire sizing. I like to have a buddy to check my math and you're all my buddy on here
My goal is not to fit bigger tires, lift, or chop, but rather to see how changing the offset will affect the vehicle (specifically scrub radius and drivability) and as far as I read, I didn't see much information about this.
The recommendation in the first post is to keep 4.1" to 4.5" of backspacing which doesn't really play into wheel well rubbing, but more scrub radius, correct? I'm looking to get aftermarket wheels which would be 8.5" wide (stock is 7.5) and have a -18 offset (stock is 15). The backspacing would go from 4.33" to 3.5" with the proposed wheels so then it seems that this would cause rubbing not when driving straight but when making harder turns.
I believe the decision is to not go with a wheel having these dimensions and look for something that keeps the backspacing within the recommended range.
Thank you for helping me validate my thought process (or finding holes in it!)
