Charcoal Canister / EVAP System Delete?
Clayton74
Did quite a bit of searching on here and I couldn't seem to come up with anyone that's done this before.
Has anyone deleted this system before? Check engine light doesn't concern me, but I don't want to affect performance. I was basically just planning to plug / cap / remove the lines and canister. It would make a good place to relocate my washer reservoir.
I have wondered the same thing as I have had EVAP codes set off the CEL on numerous 4Runners of the third Gen. I have a non CALI right now and, knock on wood, never had a CEL. I don't see how removing the system would harm anything performance wise, but I'm definitely no pro mechanic.
EVAP codes can be a ***** to track down. It can be the gas cap, but not usually. IT is a tough system to troubleshoot unless you have the correct tools to analyze. Let me know how it goes after you remove it.
Look what I found cleaning up my photobucket account. I had this saved way back then. I haven't try this mod as I live in a enhanced biennial smog check area. I know some have successfully done the charcoal delete. Let's see if you can use this...
I wish, wouldn't pass inspection where I live if I did that.
Had an EVAP code every couple hundred miles for a while. Just kept resetting it. Haven't seen it in about a year now, so yay?
Thanks, this will make a good start. We don't have emissions in AK and my rig is mostly for off-road anyway. I was considering just removing the bulb in my dash for the CEL but I'll wait to see if this keeps it on all the time.
@Clatyon74 - Did you end up removing yours? Update?
I have not removed it yet but it's going to go. Been too busy with other "mods". It's definately on the plate though because my washer tank had to get pulled the other day and no washer fluid sucks.
Why would you "delete" the EVAP system?
Couple of reasons
1) I don't need it, my rig is for offroad
2) I need to relocate a washer canister to somewhere else as I had to remove it for clearances
3) It's a useless piece of emissions garbage
4) The OCD in me hates listening to that buzzing all the time.
Yeah, because breathing clean air sucks!! :llama:
This is more trouble than its worth. Where are you planning to vent the fuel tank to? Might as well just vent it into the interior since the EVAP system is useless to begin with! :pound:
At least with the 4th gen, The purge valve is naturally closed so if you just unplug it and leave it there, vapor has no way to get to the intake. just make sure to unplug the vent valve too (it naturally stays open) so pressure doesnt get too high in your tank. If you remove the canister you will probably be smelling gas often.
More trouble than it's worth for you. Not for me because it's really no trouble. My rigs not a pavement queen where my cool mods consist of custom grilles and retrofitted headlights (no offense to those that do these mods, to each their own), it's an off-road rig meant to replace my Polaris Ranger.
Where do you think most gas tanks vent to? Typically they have an open vent to the atmosphere and is pulling air most of the time when the vehicle is running. The main time air comes out is when you're filling your tank.
This mod isn't for most. If you've got a DD, you probably don't want to gut your evap system.
I've done exactly this and have been using it for the last year or so. Yep, IO get a CEL from it. No it won't pass smog but it's also a trailer queen. It's not like I am driving it 300 miles a week. I didn't have room in the engine bay for it to stay. I needed a tire to go there instead.
I deleted mine and drive it every day with no cel. Find the diagram for the 3.4l swap in a 3.0 truck and use that vacuum layout for the 3.0 charcoal canister only leave out the canister. Works fine on my 96.
PRWhite
