Check Engine, TRAC, AND/OR VSC On? Read Me!
I'd clear the codes and monitor it. Some of the C codes could be from when you had alternator/battery issues. The P0430 is pretty common on a high mileage Toyota, could be from weak cats, leaky exhaust or lower o2 sensor.
Just for reference my 4runner has 137k miles with the 4.7L V8
I did clear the codes right away, and they came right back up after driving about 30 miles again… Sounds like I may need to do a cat delete if thats causing some of this
I may bring it back to that shop and see if they have any ideas. I just dont want to start blindly replacing parts if it’s not needed. Sounds like there may be fuses that can cause some of this too? I’ll take a look at that tomorrow as well, but if you have any advice on what to look for itd be greatly appreciated!
There's a ton of threads for the p0430 code. The downstream sensors work a bit differently than the upstream ones but I think you can still check that you are getting voltage on the O2 heater wires. The C codes are an unknown to me and I'm not sure if they clear the same way.
When no issues with the circuitry, some folks put spark plug non-foulers between the sensor and cat to skew the numbers slightly. I've had the low efficiency code go away by putting better quality fuel or higher octane, gets me through state inspection. :)
I tried Cat Clean, and higher octane fuel. Sadly now I have both P0430 & P0420 codes among the others. Guess I should take it to the shop
Is the forum weird for anyone else?
Anyway, here's where I am in my own VCS/TRAC/ABS dash light saga;
My Dastardly 3 lights are on with the Brake light but NOT the CEL. Several years ago I had the ABS codes scanned and it indicated the right rear wheel sensor which I replaced, lights did not go away at that time but I lived in FL with no vehicle inspections so I just left it alone. Fast forward to now, I live in TX and I need to get this truck through an inspection annually. I have replaced the fuel cap (which I believe is more of a CEL-related problem) which did nothing. I replaced the brake light switch, no improvement. I am up against a clock now so I pulled both rear sensors off and unplugged the wiring harness from the connector above the rear diff. Sprayed electronic cleaner on everything, tested continuity between the ends and the plug and everything checked out. Added some dielectric grease and plugged everything back in. I also cleaned off the sensors and sprayed some brake cleaner down in the sensor hole hoping the maybe clear anything that might be on the reluctor/pickup. No improvement after all of this. I did notice that the right side rear hub has a definite layer of oily muck on it, much more so than the left side. I had a bad wheel bearing on that side that I had replaced back in 2021 so I am hoping that that is just residual muck buildup. Did a Zero Point Calibration and this cleared the lights long enough for me to make it out of my driveway at which point they all came back on again.
I finally invested in a good OBDII reader and hooked it up, I am pulling 3 codes C0210 (Rear Speed Sensor RH Circuit), C1223 (ABS Control System Malfunction), C1336 Zero Point Calibration of Deceleration Sensor Undone. I can clear these with my reader but they all come back on after a very short drive. I am hoping that there is something in the harness between the plug above the rear diff and the ABS module itself and will have to crawl back underneath it to do some testing.
Questions;
1. Would the failed right rear wheel bearing and differential fluid leak have damaged the sensor or the pickup? I had replaced the sensor on this wheel prior to having the bearing & seal replaced.
2. What kind of voltage readings should I be seeing at this plug?
Questions;
I can't really help you with your issues other than to say that "dielectric grease" is non conductive and should only be use to help keep water/dirt etc. out of electrical connections, if the dielectric grease is on the actual contact areas of the electrical connection it could cause a bad connection.
I've used dielectric grease on electrical connectors for decades and never had a connectivity problem. But YMMV.
I “hope” the CK Eng Light and VSC TRAC lights are off and solved. “Before the recent info.”
1. I took the advice of getting the truck scanned for a code and it showed a small leak at the gas cap. I d/n think to ask the Tech for the code vs him tell and what it represented.
2. At this point I noticed no resistance of a seal on the cap and the good bad “Soft O-Rings” shows why. Plus, the old was not pushing the cap off enough to help remove the cap (attached).
3. The Tech said the light should reset later. I asked if the scanner would detect the leak as solved and it did (the light also went off).
4. To and from the Auto Store the back driver’s side window went down on its own. Is there a connection there?
I just cleaned the "O Ring" and greased it on the gas cap then using my Hyper Tough OBD-ii/EOBD code reader bought for $23 at Walmart and cleared the codes and stopped the check engine and the flashing Anti Skid allert.
I still stand behind my thoughts that it's a scam of Toyotas to try scaring people to their Stealer Dealers Non Service Dept. where they can find a lot of problems for you to pay them to fix.:gun6:
Questions;
I have had success!
I lifted the rear end put it on stands and removed both rear wheels. This gave me easier access to both rear wheel sensors. Since I was only getting a code for the right one I tested voltage at the plug on the left side and sure enough on one of the two terminals I have 10.8v.I tested the other side since I had a good baseline and I had 10.8v on the right as well. So I didn't have a wiring problem, one possibility eliminated.
Next I removed the right side sensor and it was wet with oil. recall that I had a leaking seal and bad wheel bearing, both replaced a couple years ago. The back of the brake plate & hub is are coated in oily residue & showing some signs of the leak not being completely fixed so that'll be something to deal with. However I sprayed brake cleaner down the sensor hole and spun the hub by hand to make sure I cleaned off the pickup ring on the axle all the way around as best I could. I had picked up a replacement sensor already so I plugged that in, reattached the wheels dropped it to the ground and reset the ABS codes. After a quick test drive the lights didn't return!
TL;DR I replaced my wheel speed sensor, cleaned the pickup ring on the axle and cleared the codes and I know longer have a dash filled with bright lights! Its been clean since Sunday with regular commuting every day this week.
What is the next step?
So, this seems to be a constant source of confusion for many members as of late and since I have some time to kill, I figured I'd help clarify some things in an attempt to help members with this issue in the future.
On the 4th Generation 4Runners (this applies to a lot of Toyota SUVs, Minivans, and some cars as well) when an OBD-II DTC set and stored in the system, the MIL, TRAC, and VSC lights will always come on to indicate a fault in the OBDII System. If you have an ABS capable scantool you will see a DTC C1201-Engine Control System Malfunction, this DTC is always set when an OBDII DTC turns on the MIL; its the code that shuts off the VSC & TRAC systems and turns on the lights on the dash . Don't be worried about this DTC, when you correct the original DTC(s) that set the MIL on, the C1201 will erase along with the original codes with a scantool.
Before we delve into the how's and whys, lets first clarify some terminology;
MIL- The MIL or "Malfunction Indicator Lamp" is the SAE (Society of Automotive Engineers) term for the colloquially referred to "Check Engine Light (Sometimes abbreviated as "CEL") and is most often shown as a small engine block, sometimes "Check" is under the icon or in some other vehicles "Service Engine Soon" is used instead.
Examples of MIL Icons:
TRAC- TRAC is the abbreviation used by Toyota (and some other manufacturers) for Traction Control System. This is system is often used in combination with the VSC and ABS systems.
VSC- VSC is another acronym for Vehicle Stability Control and is often what you see when the vehicle is skidding/sliding as the vehicle tries to regain control; this is often in conjunction with the ABS and/or TRAC systems.
OBDII- This stands for OnBoard Diagnostics Generation II, this a standard of automotive self-diagnostic system(s) created in conjunction between SAE, EPA, and Vehicle Manufacturers. If you'd like to learn more about OBDII here's a helpful website; OBD-II - On-Board Diagnostic System
DLC- This is the 16 pin OBD-II mandated connector that all factory and aftermarket scantools communicate through and is mandated by OBD-II regulations to be mounted under the driver's side dash area. (On the 4the 4th generation 4Runner it is located underneath the access panel for the interior fuse block)
DTC- Another SAE term that stands for Diagnostic Trouble Code; these are designed to help aid diagnosis of a problem and identify a system that may have a problem, and example of a DTC would be a P0455- [Emissions, Gross Leak Detected] (A helpful break down of how to understand DTCs if you want OBD-II Codes Defined)
PCM- PowerTrain Control Module, the heart and brain of most modern vehicle's fuel injection, ignition, emissions, and sometimes transmission control systems. This puppy make your 4Runner go vroom vroom.
Now that we have some of the terminology explained, lets get into the two most common issues people run into:
MIL OFF, TRAC On, VSC On (and maybe ABS On IF an ABS code is set also)- There is a Non-OBDII Failure in the ABS/TRAC/VSC system and it requires an ABS Capable Scantool to pull accurate codes from, this is NOT an engine or emission related issue. Most Autoparts stores should have a capable scantool to get codes, but you may have to go to an independent shop and/or the dealer. An example of a failure of this type would be a speed sensor or failure in ABS wiring, ect. (Note that in 2003~2004 4th Gen 4Runners, low battery voltage and/or clearing DTCs can sometimes undo the ZPC (Zero Point Calibration) value stored in the ABS Module, this will result in the TRAC & VSC warning lamps turning back on despite having "fixed" your MIL condition.)
MIL is Blinking- This means there is a catalyst damaging misfire occurring (this is an OBDII mandated requirement and is present on all OBDII vehicles), you need to stop the vehicle and turn it off; failure to do so can result in permanent damage to your catalyst(s).
MIL On, TRAC On, and VSC ON- An OBDII failure has occurred in the vehicle that affects Engine Performance and/or Emission Control Systems and does not need a factory-capable scantool to pull codes (this means you can use a code reader from an autoparts store and get accurate codes) An example of this type of failure would be a Misfire, transmission issue, EVAP issue, ect.
Now I want to go into detail a little on the above mentioned OBDII failure because MANY people on almost EVERY forum there is incorrectly associate the MIL with a "Loose Gas Cap" and it gets repeated over and over and over again like some sort of magical "get out of jail" card...
An MIL on condition means there is an OBDII Failure Present in your vehicle that affects Engine Performance and/or Emission Controls and a DTC has been stored in the PCM. A loose gas cap COULD be the cause of the issue, but it more often than not is not even close.
Helpful Hint- If you have a P0455 DTC and ONLY a P0455 DTC stored in your pcm, then the gas cap MIGHT be the issue. A P0455 indicates that the EVAP Control System has found a leak over .040" and could not pass its monitor. This means you can replace the gas cap and still have the same DTC set if the leak was not the gas cap but somewhere else. Please also note that it can take a couple drive cycles to reset the MIL (without using a scantool) if the issue was in fact a loose gas cap, this often means anywhere from a day to a week or more depending on driving habits.​
Helpful Hint- TSB 0030-10 indicates a prematurely failing gas cap as the cause for DTCs P0441, P0455, and/or P0456. The easiest way to rule the gas cap (this isn't 100% accurate, but works the majority of the time) is to tighten the gas cap until it "clicks", the gently unscrew it. If the cap has no resistance and unscrews it requires replacement, if the cap takes some effort to unscrew it's most likely good.
If you do have an MIL On condition, I highly recommend you go to a local autoparts store and have them pull and write down the DTCs stored in the vehicle before you post on the forum. The first thing we need to help you out with an MIL On condition is what codes are stored in the PCM; no one can do anything for you until we know what we're dealing with. This will save you the trouble of waiting on us to tell you to get the codes pulled and will help you get accurate information in a timely manner rather than taking days to get to any real significant assistance or direction.
I will also mention that some people may have scantools that indicate "Current" and/or "History" DTCs, these mean that the DTC was set by an issue that is occurring right now (Current) or that the issue has occurred in the past and the vehicle recorded the DTC for later review (History.) Typically only Current DTCs will set a warning lamp and History DTCs will simply show up when you do a health check; its important to know this distinction as you could pull up a History DTC for a problem and end up wasting time and effort trying to diagnose an issue that is not even present. Another type of DTC category you may see is "Pending", a Pending DTC is part of the "Two-Trip Logic" that OBDII dictates and some other modules use as well. Two Trip Logic means that the problem has to occur twice before the vehicle will set a "Current" DTC and turn on the MIL, a "Pending" DTC means that it has only happened once and the vehicle will not set an MIL on condition until it trips a second time and the DTC matures to a Current DTC (for example a P0420 or P0430 "Current" DTC means that the ECM ran the catalytic converter tests at two different times and returned two failure results, where as a Pending P0420 and/or P0430 means that the ECM ran the test and got a failure once and is waiting to see if it happens again before it sets the MIL and matures it to a Current DTC). Some modules such as SRS and ABS/VSC/TRAC do not use Two Trip Logic and will instead set a warning lamp on the first sign of an issue, these systems are "Single Trip Logic".
But if it makes you feel better you're more than welcome to tighten the gas cap and wait a few days to a week to see if the lights go away if you want, we'll still be here anyways.
Post Note-
I realized I never explained why the VSC & TRAC systems are disabled when an MIL is turned on. The simple answer is because Toyota is conservative and decided that since 9/10 the MIL is turned on for an OBDII DTC (which, except for a small handful of EVAP related DTCs directly impacts engine performance) that it meant the engine is not working as designed and cannot be trusted to work correctly with the VSC & TRAC systems when demanded (VSC & TRAC modulate ABS and Engine Output to bring the vehicle under control at times.) So the easiest and conservative solution is that when an OBDII DTC is set (i.e. an MIL is turned on,) they disable the VSC & TRAC systems because half the system has an issue. A lot of manufacturers have started to do this in the last decade as these vehicles get more and more complicated.
I have had this MIL VSC TRAC lights coming on for a while. I have tried just about everything and am not sure what to do next. The MIL came on out of the blue while driving on the highway. Then of course the VSC and TRAC lights came on. I have done a few things to try and get them to go off. First, I did get the OBD scan on it the only code that came up was P0430. (BTW - I have an 04 T4R 4th gen with 217,000 miles 4WD 4dr sport V8)
Then I went to the auto parts store and got the fuel additive Cataclean. I followed the directions and much to my surprise, the lights went out after about 35 miles of hiway driving. I filled up the gas tank. Lights were off until about 1/2 a tank then they came back on again. I tried disconnecting the battery and putting the positive and negative cables together for 10 minutes or so to reset everything. That didn't work. I tried several more brands of catalytic cleaner and most of them worked but for a short period as well.
What should I do now? I'm guessing the catalytic converter is going out or the MASS air flow sensor? One of the oxygen sensors? IDK. Its running kind of rough now sometimes and shakes pretty bad when I am slowing down and applying the brakes. Maybe that's all related and maybe not?? I have to get an emissions by the end of June. I don't want to be trying to fix it last minute if I indeed have to do that. I can't afford mechanic shops, so I fix most everything myself. Not sure I could handle putting in sensors and a converter. What I am sure of is I need my car!!
I would like some direction as to what I should check next etc... Thank you, Dena
Old post, new answer. I also just had P0430, bank 2 code and P1201 which lights up VSC and TRAC lights. This happened right after driving in the rain so guessing something in the O2 sensor wiring is not right. Anyways, MIL is stored in engine PCM while VSC and TRAC are stored in ABS module. I erased both modules and also did OBDII reset as well.
2001ATL
