Check Engine/VSC Off/Trac Off light all ON 2004 V8
yotanoob
Hey y'all,
Ran into a little problem this morning on my way to work. Was driving down the freeway and my Check Engine, VSC off and Trac off light all came on. Unfortunately when my car got broken into a month ago they stole my OBD2 Scanner :50cal:. So trying to pinpoint the problem before I drive home from work. Yesterday I did a few maintenance related fixes to the truck. Replaced battery with Optima Yellow Top, replaced PCV valve, changed oil used Amsoil 5W30 Full Stnthetic Signature Series with BG MOA. I also added BG 44k Fuel System cleaner to a full 20 Gallon gas tank. The truck run fine I just would like to keep the mileage as low as possible with the lights on. Has anyone had this issue when changing the PCV valve or changing oil?
The truck is a 2004 V8
AndiGarage
