Awesome build man. On the sliders, were the removable top plates a custom order thing or are they now making them all bolt-on rather than welded on? I really like the idea of being able to remove them if you choose.
Thanks, dude! what a great move that was! I've been racking my brain on what to do with the wire, and this is the perfect solution. super clean. i refuse to drill through the roof to run the wire, and this solves it. thanks again, and great looking build. FYI, I've read that the bushwackers can damage the paint, so you may want to put in some 3M protective tape like you did with the wind deflector. i actually did the same exact thing with the wind deflector.
Did you have to remove the weather stripping to do this?
I figured, but was hoping there was another way. The wiring harness on the Baja lights have such thick wires that just tucking won't work for me. I can't figure out a good solution
Can't you peel off the sheathing and just run the wires under the weather strip? That's what I did.
I did try that. Spent a couple of hours on it. Barely was able to get one wire in - no chance of getting both. Not sure if it's the gauge of the wires or just the way my truck is rigged. Only other thing I can think to try is removing the weather stripping and then hoping i can replace it and that it fits snugly on top of the wires without affecting the seal.
[MENTION=62757]chudiddy[/MENTION] your set up is amazing! I have the hybrid bumper coming in a few weeks. What winch are you using and what is that orange piece on the outside of the bumper holding it there?
Hi thanks a lot! I went with the Warn Zeon 8-S. The orange piece is the Flatlink made by Factor 55. You can get it here:
FlatLink | Winch Safety Thimble | Factor 55
thanks for the info. it appears you shaved the rounded ends off the lens covers and cut some sort of rubber/plastic cover to slip over the front, correct?
they fit really well in those grill slots with the ends trimmed off. great work
What did you do to prep the metal and then what paint did you end up going with? I'm very interested in those sliders!
Update...
New Fuel Tank Skid and Sliders are mounted. Still a few more things to do.
Really can't say enough about the quality of the skid and sliders. Wonderful craftsmanship and build quality. Super pleased with them.
