CK eng light, VSC blinking, TRAC light on TSB
AE1M
Member
This morning my 2008 4R Limited displayed the Check Engine light, the VSC light was blinking and the Traction light was on. There are other threads about this but I thought I'd post a clean one.
Took it to the dealer and there is a TSB out for the gas cap. Has some issue that develops over time, I was unclear as to the actual reason.
Anyway if that issue develops, no amount of fiddling with it or filling the tank seems to fix it. The dealer wanted an hour of labor and then $21 for a new gas cap. I have the 100K extended warranty so it was covered as a TSB, the warranty doesn't otherwise cover it.
So, if you have this issue, I suggest just buying the gas cap and installing yourself. You need to go through several "drive cycles" for the ODB code to clear, or you can clear it with a scanner.
Hope the info saves someone else some headaches. Of course, you may have another cause, but this is a cheap way to start a diagnosis if you want.
B
TSB? For the gas cap? This is new, I'll see if I can find the TSB at work tomorrow... still very weird to hear, glad it worked out.
From the RO, the code being thrown was P0441 and the TSB is 0030-10.
Found this:
MIL "ON" DTC P0455 & P0441 or P0456 (T-SB-0030-10)
Some 2005 – 2009 model year 4Runner vehicles may exhibit a MIL “ON” condition with one or more of the following DTCs: P0455 & P0441 or P0456.
on this site:
Toyota Technical Service Bulletin Index
I have the same problem started a couple of days ago. Codes P0441 and P0455, the VSC light, and the Traction light are on. I'm not sure how the Evaporative Emission Control System is related to VSC and Traction. I re-tighten the gas cap for now and will wait a few days to see if it go away. The link to the Toyota Technical Service Bulletin Index is not working. Can you please give the correct one? Thanks!
Read more at: OBD-II Trouble Code: P0441 Evaporative Emission Control System Incorrect Purge Flow
Copyright © OBD-Codes.com
Found this:
on this site:
Jhunt
