99yota4
Hey guys, I began my installation after receiving some help here about wiring. Now I connected majority of the wires according to my vswd crib sheet and using the installation manual for the clifford 50.7x. I'm installing my security/remote start into a 1999 toyota 4runner. The reason for all my confusion is because I think the previous owner had his own aftermarket security system and alot of the wiring is in different places. Here is what I connected so far and the ones with a question mark are the ones I need to get help with.
Harness # ~ Color ~ wire location in vehicle ~ Vehicle wire
H1/1 ~ Red/white ~ not connected ~ n/c
H1/2 ~ Red ~ Ignition harness ~ White
H1/3 ~ Brown ~ red wire of the siren, fed the wire through firewall grommet
?? H1/4 ~ White/Brown ~ ??
H1/5 ~ Black ~ Driver side kick panel ground
?? H1/6 ~violet ~ ?? (do i need to connect this?)
H1/7 ~ Blue ~ N/C
H1/8 ~ Green ~ driver side Kick panel ~ Light green/black (-)
?? H1/9 ~ Black/white ~ ??
H1/10 ~ White/Blue ~ N/C
H1/11 ~ White ~ set to negative
?? H1/12 ~ Orage ~ ??
H2/1 ~ Light Green/black
H2/2 ~ light Green/white
H2/3 ~ White/Violet
H2/4 ~ Violet/black
H2/5 ~ white/black
H2/6 ~ light blue
H2/7 ~ gray/black
H2/8 ~ brown/black ~ Steering Column ~ Green/red (-)
H3/1 ~ Pink ~ Ignition harness ~ Black/yellow
H3/2 ~ Red/white ~ ignition harness ~ black/red
H3/3 ~ Orange ~ ignition harness ~ Blue/red
H3/4 ~Violet ~Ignition harness ~ green/black (starter side)
H3/5 ~ Green ~ ignition harness ~ green/black (Ignition switch side)
H3/6 ~ Red ~ Ignition harness ~ White (constant 12v)
?? H3/7 ~ pink.white ~ ??
?? H3/8 ~pink/black ~ ??
H3/9 ~ red/black ~ Ignition harness ~ White/red (constant 12v)
Remote Start Input
1 ~ Black/white ~ Grounded in driver side kickpanel
2 ~ Violet/white ~ Engine Compartment Diagnostic plug (tapped into the black wire for tach)
3 ~ Brown ~ driver door sill ~ Green/white (+)
4 ~ Gray ~ Hood pin Engine bay ~ Wired through firewall grommet and attached to the supplied wire connector to hoodpin switch
?? 5 ~ blue/white ~ ???
Remote Start Output (Do i need to connect any of these if I don't have any additional modules, sensors, or accessories?)
1 ~ Pink/white
2 ~ Orange
3 ~ Violet
4 ~ Pink
?? 5 ~ Blue ~ ?? ( Where do I connect this?)
Doorlock wires (How do I wire this up??)
( I have a type B door lock according to the vswd. 3-wire (-) pulse controlling factory lock relays.)
1 ~ blue
2 ~ empty
3 ~ Green
Additionally, I'm trying to find the "CLK, DATA, SYNCHRO, GROUND, KEY SENSE" wires for the XpressKit PKALL. (Data immobilizer override)
- In the install manual for the PKALL, it says
CLK - Red/Black
Data - gray/red
Synchro - pink/black
Ground - Brown
Key Sense - Yellow/red
I think I found some of these but I'm not sure if it's correct. Please tell me where I can find these wires and how to connect them.
Also the Blue/White from the PKALL, where does this connect to?
Please help and Thank you for taking the time to read this!!!
H1/7 ~ Blue ~ N/C
H2/3 ~ White/Violet
H2/4 ~ Violet/black
H2/5 ~ white/black
H2/6 ~ light blue
H2/7 ~ gray/black
Remote Start Input
1 ~ Pink/white
2 ~ Orange
3 ~ Violet
4 ~ Pink
1 ~ blue
2 ~ empty
3 ~ Green
CLK - Red/Black
Data - gray/red
Ground - Brown
