Climate control stuck at HIGH
ukrsindicat
Junior Member
First time using the heat on my 4Runner this season, and it looks like it’s now stuck on the highest temperature setting. The temperature on the display doesn’t respond when I press the controls. Where should I start troubleshooting?
Here’s the video of the issue:
- YouTube
Blend door actuator could be bad. Fairly sure it is the Air Mix Damper Control Servo. If you have Limited, there will be a second servo on the left side. I changed the left side servo in mine. It is easy to get at for DIY.
AndiGarage
