Probably going to use a combination of these little guys for the 7th and 8th injector to get a good fuel curve.
They are very compact, only 40mm long.
They come in a large range from 275cc to 2200cc.
Use common EV14 connector.
Relatively inexpensive.
You planning on injecting gas right into the intake??
Just read through the entire thread! Holy s*** dude! I had been wondering about rear turbos with mud and water (I had seen part of your build before, just not the whole thing) and I like the new snorkel setup much better than the rear. I have the time just not the funds, but eventually I will have this setup! Did anything ever come from the column paddle shifters?
How are you going to tune closed loop boost?
And FWIW my stock fuel pump is properly feeding 550cc/min injectors at 9psi at 10.5 AFR.
