JayRolla
So it's been turbocharged making good power and been reliable for 5 years now. I know the AFR has never been perfect and probably lean, but it worked. I recently wanted to start turning up the boost a bit so a wideband was going to be mandatory at this point.
After driving it home today after installing the 255lph pump I now know first hand the stock fuel pump can't even keep up with the little stock 240cc injectors at high rpm with my setup at 7psi.
Full throttle open loop pulls AFR would drop to ~11 and stay there until around 4.5k rpm and start going lean fast ~14 which is bad. With the new pump it drops to ~10 and never goes above 13. Step in the right direction at least. Pulls harder and feels a lot better over all.
This pump is the backbone and a starting point to more boost and more fuel I am going to force feed this pig, and she will take it like a boss or blow the intake manifold through the hood.
Your issue is not the fuel pump. Your injectors are hitting 100+% idc most likely. That pump can handle the low boost easily. I'm guessing low voltage or it was failing. 13 is very lean. Your still having the issue.
Your running a 255lph on stock fpr?? Never heard of a stock one handling that size of pump. Will make tuning really tough.
Also what you going to tune the injectors for closed loop?
