Confused with elocker retrofit gauge cluster wiring 98' 4Runner
Silver.T4R
Sorry if a thread for this already exists, but I've spent the last hour searching and haven't come across anything. I'm in the final stages of swapping in an elocker axle into my 98' and have been following @timmythetoolman's (huge thanks Tim!) video and a couple threads on here. I'm almost done with finishing up making the harness, but when I went to wire up the dash light indicator (pin #5 according to the video) I already have a pin there? I also saw that I have a connector behind where the diff lock button typically goes in the dash that looks similar to the connector that plugs into the diff lock ECU, however I don't have the wiring for the elocker button.
Does anyone know if the elocker indicator pin plugs into a different spot on a 98' than a 99' gauge cluster? Or is mine partly prewired?
Some pics:
Wire currently taking up where pin #5 would go on the gauge cluster
InkedPXL_20210929_035630547.NIGHT_LI | Flickr
Connector behind where the diff lock button would go, it looks just like the elocker ECU pin other than its missing some pins?
PXL_20210929_035652442.PORTRAIT | Flickr
I don't have the answer for you, but the 99 cluster is completely different from the 98 cluster. You need to find info for 96-98 specifically to make it work.
Some pics:
I just started doing a similar mod(with ARB locker) and I have a 98
from what I know the clusters are different
96-97 same
98 unique to 98
99-00 same
01-02 same
I know the trim levels also have some differences but unsure if it matter in the locker pins.
I was out at the junk yard yesterday and pulled the pigtails from a 98 that was factory wired with RR dif lock. The brown and Blue connectors are the ones you need to see from the combination meter.
<a href="https://imgur.com/xgMDQ2i"><img src="https://i.imgur.com/xgMDQ2il.jpg" title="source: imgur.com" /></a>
<a href="https://imgur.com/yrVCGKO"><img src="https://i.imgur.com/yrVCGKOl.jpg" title="source: imgur.com" /></a>
and here is the wire diagram for the 98
<a href="https://imgur.com/Yqm9Y6q"><img src="https://i.imgur.com/Yqm9Y6ql.png" title="source: imgur.com" /></a>
<a href="https://imgur.com/HiDBskh"><img src="https://i.imgur.com/HiDBskhl.png" title="source: imgur.com" /></a>
<a href="https://imgur.com/jlZSzN6"><img src="https://i.imgur.com/jlZSzN6l.png" title="source: imgur.com" /></a>
so I think?
C10 12 volts brown connector combo meter pin 8 yellow blue(lavendar?) Y−L
C11 ground always blue connector combo meter pin 5 B−Y
here is the complete 98 electrical
Toyota 1997 4Runner Electrical Wiring Diagram (EWD277U).pdf - Google Drive
Sorry for the late reply, the last few days have been pretty busy.
Thanks [MENTION=168172]sleepydad[/MENTION], those diagrams were exactly what I was looking for but I wasn't able to find that part of the FSM online. I figured there was probably a difference between the clusters but I wasn't sure. I checked my cluster and I have the ground wire in the diagram already in place, the only wire I'm missing is the indicator wire. I was an idiot I accidentally broke the pin off of the indicator wire and am currently waiting for the new pin to come in though it should be here in the next couple days, I'll update with the results once I get it wired in.
oh bummer oh well stop breaking pins!
I gave you the wrong link I see this one is for 98
1998 4Runner Electrical Wiring Diagram EWD319U.pdf - Google Drive
confirmed the indicator is neg- switched, I'm not quite ready to wire mine still waiting on some wire and lugs I ordered.
Some pics:
My apologies for the confusion here, my 4Runner in the Timmy video is a 99 and is indeed different, looks like sleepydad saved the day here.
Enjoy!
Quick update, the dealership got the new pins in faster than I was expecting and I just finished up the wiring this afternoon and everything is working great! Huge thanks [MENTION=168172]sleepydad[/MENTION] for the diagram / picture of the connector pin #8 in the brown connector was the right pin for the 98' and the diff light is lit up as soon as it was plugged in.
Enjoy!
No worries [MENTION=174573]wrench.n.wheel[/MENTION], thanks for explaining the wiring diagrams and using your Runner for the video. I figured I'd probably have to do a little searching on here too and there's no way I would have tackled this in the first place if it weren't for the video you and tim put together.
Do you happen to have a part number or link for where to buy these pins? I'm gonna be doing the same thing but with my ARB, I figured they were something common that you can get pretty easily but am struggling to find exactly what they are
This is the part number you're looking for. I got it from the video I shot with [MENTION=174573]wrench.n.wheel[/MENTION] (aka Seydzh).
* Pin that goes to the back of the dash cluster connector plug to light up the dash when the elocker is engaging/engaged Part #82998-24180
82998-24180 Genuine Toyota Terminal, Repair W/W.
<iframe width="560" height="315" src="https://www.youtube.com/embed/qAznG_WoS44" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
t
t
Should've known to check your video, thanks a bunch Tim!
