Consolidated Lighting Info Thread
7S H11 White LED for Projector Headlights
Has anyone used these H11 LEDs in the headlights? They claim to be specific to projector housings.
JDM ASTAR 7S H11 White LED for Projector Headlights
JDM ASTAR Auto LED Bulbs,LED Headlight,Fog Lamps & Turn Signal Brake Tail Light
H11 LED replacement bulbs are engineered for superior performance, exceptional looks, and increased safety. Especially designed for upgrading the headlights,fog lights,DRL.
Features:
Each bulb has 1 pieces high power cree XHP70 led chips.
Lumens output for each bulb is 4000 lumens Per bulb(in white)
Our LED bulbs are engineered for superior performance, exceptional looks, and increased safety.
Longer lifespan: last up to 20,000 hours in 25°C ambient.
Fits H11, H8, H9. Color: 6500K xenon white.
Used for headlamp,fog light,DRL(daytime running light) replacement.
Aluminum heat sink design,built-in automotive circuit to prevent electronic interference. All in one design, for most vehicles, just plug & play, easy installation.
Waterproof: IP65. Voltage: 12V to 24V.
Package includes one pair (2 pieces led bulbs) per order.
Specifications
Base Type
H11
Optional Colors
6500K xenon white
LED Lifetime
20000 Hours in 25°C ambient
LED Chips Type
XHP70
Power(Watts)
25.0W
Raw Lumens
4000lm
Beam Angle
360°
Anti-glare
Yes
SKU Number
7S-H11-4000W--ONE SIDE
Working Voltage
12V~24V
Bulb Type
Aftermarket Replacement
Smart LED Driver
Yes
Radio Interference
No
Waterproof
IP65
Just got around to putting the Lexus LED fog lights in
Was it required you take the outer bezel off?
How do they come, individual or pair.
Priced each or pair?
No, the outer bezel is not required to come off, I'm just making it easier for the PPF installer to put the film on. They come separate and are around $250 for the pair.
Any other input?
I have the XD HID kit. I didn't go with the 4300 though, I went with the 6500. At first I was worried it might be too blue, but I think it is actually perfect. I have not had to re-aim my lights or anything and I have only been flashed once since having them (couple months).
I thought if doing the same thing you are thinking of doing and I am happy with the route I went.
Hope that helps.
Has anyone used these H11 LEDs in the headlights? They claim to be specific to projector housings. JDM ASTAR 7S H11 White LED for Projector Headlights
Those are specific to projector housing in that the base fitment is H11, lol.
The most capable LED kit I've seen in the OEM projector housings is the one from XD, since it has diodes on two sides. If there's a company making a 3 (or more) arrangement diode with an H11 base, I haven't seen it, but I'd certainly like to know about it. The more that any replacement bulb matches the exact pattern of output from a halogen H11 (360 degree light output, bulb length, etc.), the better it'll act in a projector.
If you're going LED for the LBs, the XD kit is the one to go with as far as I know. I'm currently still running the H9/H11 incandescent swap which I've been really happy with but I may try the XD LEDs next.
I'm new to all of this headlight mod stuff and new to the 4Runner in general so if someone could please verify that these two products I have below are the right fitment and will play well with the truck that would be much appreciated. I have a 2017 TRD Off Road Premium. I want to maintain the DRL functionality and have read up on the DDM Saber lights as being able to go into lower output for DRL mode and higher output for high beams.
For low beams: Kensun HID 6000k H11
https://www.amazon.com/Kensun-Conve...90417277&sr=8-5&keywords=kensun+6000k+HID+H11
For DRL/High beams: DDM Tuning Saber
https://www.amazon.com/DDM-Tuning-S...0417428&sr=8-1&keywords=ddm+tuning+saber+9005
I've been doing a bit of research on upgrading my headlights and as most do I started looking at HIDs and such. I corresponded with Daniel Stern, of Daniel Stern Lighting, and am going to share his information here.
I have ordered the following bulbs for my OEM housings and will report back as soon as I get them installed. If I have the time and energy I'll take some photos but generally I don't do that.
The following is edited to remove the discussion about my wife's RAV4 lighting.
High beams [...], get https://www.amazon.com/dp/B000C9QPKS/?tag=2402507-20 . They are not some tinted or overwattage version of 9005, but share the identical filament geometry and base architecture as well as the same power consumption.
Here's the comparison:
Regular 9005: 12.8V, 65W, 1700 lumens, 320 hours
HIR1 (9011): 12.8V, 65W, 2530 lumens, 320 hours
The 9011 and 9012 bulbs have a double-wide top ear on the plastic bulb base, this is
to comply with the law requiring different bulbs to have different bases.
The extra-wide plastic top ear is easily trimmed or filed to make the bulb
fit your headlamp's bulb receptacle. Once that's done, they go directly
into the headlamp, and the existing sockets snap on. Please see
HIR bulb base modification for details. Disregard Amazon's warning that the bulbs won't fit your car.
[...] low beams on the 4Runner: http://www.amazon.com/dp/B00BQWQN1Q/?tag=2402507-20
Fog lamps on the 4Runner: No legitimate upgrade.
Fog lamps [...] should be turned *off* just about 100% of the time. Please see Daniel Stern Lighting Consultancy and Supply for thorough information about what fog lamps will/won't and can/can't do.
Of course, your headlamps and fog lamps _must_ be aimed carefully and correctly per
Daniel Stern Lighting Consultancy and Supply with any bulbs, but
especially with these high-output bulbs.
If you keep reading the DDM thread you'll see that they flicker in DRL mode. There are currently NO LED options for the HB spot that don't either run as full brights or flicker in DRL mode. If you're dead set on having LED HBs and normally functioning DRLs (not full brights nor flickering), you'll have to change your DRLs to a different spot (i.e. having the fogs be your DRLs)
can anyone comment on which ones ordered from XenonDepot need Canbus option?
If you're referring to the XD HID kits, none of them require CANBUS.
AndiGarage
