So I was sitting in my truck with the AC running when I suddenly here my Ultra Gauge warning chime go off. Took a look and it said coolant temp warning. Hadn't even notice while I was sitting there that the gauge on the truck rose to nearly H!
Shut the truck off immediately popped the hood and check my coolant and the reservoir is nearly empty! Now the temps have been crazy high all week around 100 so I have been doing a lot of sitting and running the AC. I check often and have not noticed any leaks or anything on the ground. Could I have just used up all the coolant with it being so hot and the truck having to work overtime? I have the tranny cooler bypass so no pink milkshake. Going to grab some coolant when I leave work. Anything else I should be worried about/look for?
Thanks!
Volley
Thanks!
Volley
