Correct amount of rotational resistance in rear wheels?
ScooterMD
Curious if anyone knows how much resistance to spinning the rear wheels should demonstrate when the rear axle is elevated and the transmission is in neutral? ie should the wheels spin relatively easily (several rotations before stopping) or is it normal to rotate for only half turn or so before resistance stops them? thanks in advance.
2007 Sport V6 4wd
2007 Sport V6 4wd
I'm not sure what the correct answer is gonna be, however when I'm in park I get around 1 turn on the rear wheels before they stop rotating.
I mean it should spin freely, but you have drag from the differential assembly and driveshaft even in neutral... so I'd doubt it'd get more than 1 spin if you really rolled it?
