Couple 3VZE problems, need help/advice
captainsc
I have 92 4runner with the 3VZE-4x4. Its been having a bad miss under load and it turns out that Cylinder 5 injector is bad and it has an intake leak. Does anyone have a How To on romving the intake manifold and advice on the process? I want to replace the intake gasket and im debating on just replacing all 6 injectors? Advice/help? Much appreciated!
if you go to top of class t4r forum theirs a link to the toyota service manuals. to replace the injectors you should only need to take off your plentum or upper intake if your nor sure where the intake is leaking from spray some carb cleaner around the intake and check for changes in idle. shouldnt be too bad of a job just take your time and mark your vacume lines with masking tape so you know where to put them later their are far too many!!!:guitar2:
Rialm
