coy's 4runner thread (n_n)
end caps came in today!!
f8b7a4e0.jpg~original
gonna install these tomorrow. if the rear works on the front, which im 90% positive they will, time to order fender flares!
thanks to zacattack20 and confirming that the rear end caps fit on the front, got them on the runner!
38c3cbe3.jpg~original
b452c1ae.jpg~original
4554a2e2.jpg~original
0aab86cc.jpg~original
9576a397.jpg~original
a9af90bc.jpg~original
ordered 4 new ones at a $15+change each
if theres a good black plastic restorer kit, feel free to lmk what would be good. looks odd with the old plastic stepping part.
With those end caps you used you are going to have a few inches of gap between the bottom of the flare and the running board. The bushwacker flares are similar to the limited/sport edition flares and they stop at the bottom of the door opening.
thanks but I actually plan on just getting some and cutting the bottom portion off to make it flush with the body. I have mud flaps right now, but don't want to cut into them in case I want to put em back on in the future. With the mud flaps off, there's a little gap, so those old end caps can fill that gap on the flare, and I'll just cut off the bottom side of it. Hopefully that made sense lol. Old or new doesn't matter since I'm gonna cut and paint em anyway. If your gonna toss those old ones you had, I'll take em! :)
im fine with that small gap. i was expecting that.
as for the caps, theyre useless. theres no studs in em anymore. i just ripped em off the running board. now theres holes where they should be. i guess you could use em if you run a bolt thru the hole.
only update so far, AEM air filter with a home-made bracket to keep it from rattling around.
40C2BE6E-A4B8-4795-B240-37F7DF8C19DB-1759-000000E898AD931D.jpg~original
its the wife's rig so she wont let me change anything really unless its beneficial. haha!
sprayed plastidip on the grey plastic bits of the bumper.
6DC2F8ED-F794-4EDF-90A3-51CBCC4E5076-2492-0000013EEBF9683F.jpg~original
i did the rear as well but the lighting was bad and you cant really see it.
