crashman build thread 05 sport
Hey did you have the Factory JBL System with the stock sub woofer in that location? Just wondering before I make a custom enclosure for upgraded Alpine type R.
I had the factory job system but it has all been removed even the amp to make room for the bigger sub
I did however use the power from the amp to require the rear power outlet to stay hot all the time
I still have the factory speakers in my garage except for the dash speaker I use it for my CB
Hi rickashay
Sorry I haven't been on here for a while
Yes I had to custom cut bolts for this I went with button head hex and made them go almost to the bottom of the holes, I have been off road with these and hit them a few times, bent one in pretty good and the bolts held up I bent the ring back in shape and all is good so far
Good to know and thank for getting back to me. I ended up just dropping the coin for the real deal. Stoked to get some tires on and even more stoked to get some miles offroad at low psi!
Perfect, Thanks for the info!
I finally got my rear bumper trimmed!
So after having my tires chewed up when my wheel is stuffed from my bumper I went to Jon from The Flop Shop and had him cut my rear bumper. I can't say enough good things about them and there work! Not only did he cut the bumper but he made a plate to keep the mud out of the inside back of the bumper
Looks good. When i upsize my next set of tires I will have to do the same. i wish i had done like [MENTION=1422]the_josh[/MENTION] and had CBI change the angle of that part when they were fabricating it.
Just read through your build [MENTION=75144]crashman[/MENTION] and felt the need to bump it up after almost 2 years of it being in hiding! This rig is... :flamethrwoer2:
Thanks yeah I need to get out more and wheel I have been crazy busy
I have Some more things I need to get updated and installed
