Crawford Eco Block
While it may be fun to try to imagine what might be going on internally, none of us know enough about the internal programming to know HOW they are compensating (or not) for various variables. THAT is all pure speculation. The idea that the ECU would completely compensate out the changes cause by the spacer is speculation and in the end seems to be completely wrong.
As for babying, while my babying increased with the larger tires, I seriously doubt that was the explanation for the MPG drop, it was you know.. the larger tires, higher weight, less gear ratio and higher rolling resistance. A fairly well known phenomenon that my testing clearly backs up. Secondly, my levels of babying are the same before and after the block was installed SO that is ruled out as a variable. If anything, my MPG should go up even further now if I stop babying it maybe? In any case, that variable at this point would only positively affect the results, not negate them.
My samples are about as controlled as you can get without significant vehicle modifications and I went to some work to get them that way. My random deviations due to pump shutoff and weekend driving are smaller than the gains and losses when changing the tires and the using the spacer.
Finally, yeah frankly, (Speaking generally here, not specifically to you) if having to live with the type people who can take 100 years of research and thousands of scientists collecting data all converging onto one completely inescapable conclusion, pop their heads out of the sand long enough to yell "BULLSHIT". Combined with the people that instantly believe the most radically stupid things someone says without the tiniest bit of self reflection, or experimentation, or rational thought at all does make me frequently think that maybe this planet isn't for me :(
We know enough about feedback control loops to know that the O2 sensors in 5th gen 4Runner force the lean/rich mix to the factory designated set point. If this weren't the case, then the CEL would be thrown since the O2 sensors won't register the value commanded by the ECU. It is not magic.
If you're happy with it then rock on, but I've advised you that your data set shows a stdev that doesn't correlate properly to a controlled sample set. I've previously posted controlled test data for big rigs as a comparison for fuel consumption variation if you're interested in seeing how you compare.
YMMV
Let me try to explain it from a professional perspective. I have been making sense out of component and machine performance for 25 years. Sure, the machines and components I work with go much slower and are much bigger than a passenger vehicle but hey, math is math lol.
For you personally, you bought a component, installed it, documented data in the most non biased way possible for you and are now convinced this component works as advertised. That's fine and If I were personally evaluating it I would do the same thing because hey, what else can you do right?
In regards to your data and methodology: The longer you document performance the better your results will be. I think [MENTION=118321]Jetboy[/MENTION] and [MENTION=56924]mom[/MENTION]o have both mentioned it in previous posts. Also, using a simple average, while good enough to prove it to yourself, is probably not good enough to convince others. There are so many variables to contend with when talking about the efficiency of a vehicle. Momo asked earlier about some of them and you answered to the best of your ability. So how do you take variability out of the equation? Time and lots of data gathering. In addition to that you will need to use a trailing average of some time duration instead of using the raw data average in order to determine the actual efficiency change. Here is an example:
Every fill up I calculate the mpg by dividing miles driven by gallons used right? There are lots of variables even doing this simple task. One click, different stations, different temperatures, different blends, etc. I know you did the best you could to mitigate these variables but they exist no matter how careful you are unless you do them in a lab. In addition to that you have countless variables when driving you need to get rid of too. How do you do it? Again, time and data gathering. Let's say I filled up 10 times and got 19, 17, 18, 21, 17, 18, 20, 19, 18 and 21 mpg. The average is 18.8 mpg. Now you install different tires, eco block or something else. You do the same thing ten more times (19, 16, 21, 21, 20, 18, 17, 20, 21 and 20) and get 19.3 mpg from those ten data points. You compare the two and see you have improved a half point correct? Well, you have improved a half but why? Was it the mod or was it some other variable that caused the rise? Now let's look at it a different way. Let's add up five (in order) and divide by five to get a point average in time.
Your first point average would be 18.4. That is the first five (19, 17, 18, 21, 17) points added together and divided by five. Next you add up five more but start with the second data point. This would be 18.2 mpg. What you are doing is smoothing your mpg by using a trailing average function.What this does is take out variables. So now let me calculate it using a five period trailing average:
18.4, 18.2, 18.8, 19, 18.4, 19.2,..(one, two, skip a few lol)....and the last point is 19.2. So in this simple case, instead of increasing this hypothetical mpg by a half a gallon, by taking out many of the variables you actually increased it eight tenths!
My point is using slightly different math and taking a LOT of data points will give you a much truer picture of actual performance. I have actually volunteered to do this (even though [MENTION=121742]Quirt[/MENTION] should be doing it) just because I think the forum needs the good, real data. Quirt's a smart guy. He is selling these things based on testimonials instead of actual, real data. Much easier to do right Quirt?
If you send me your data I will start a plot and do the math. This way we can see what it really looks like with some of the variables gone. PM me for email address.
[MENTION=107119]2014 Warthog[/MENTION], I appreciate your time and effort for testing this. I think what you have been saying is you are convinced. I have no doubt on that and am glad you are happy with your purchase.
The test you have done is probably the best an end user can do. Is your test result as accurate as a lab test? I don't think so, but let me assume it's accurate enough to prove your MPG did improve. However the ultimate question is, is this kind of improved MPG good for your truck? You only recorded the MPG, but did you monitor other engine parameters? If you have some engine problem and you want to warrant it, if you are so confident, are you able to convince Toyota that block only did good things to your engine?
Well, thanks for providing a testing result that makes me not willing to risk my drive train for that little improvement in MPG.
I'll have a couple more data points for the third set soon. I plan on getting at least another 3 months so 6-8 more good readings. At that point I might be willing to remove it and see if it changes again, though 10 tanks with it removed might cost me $40!
I know what you are saying about the sample size. I've taken a few iso 9001 statistics courses and the minimum sample size to get usable results is generally considered to be 10 with two throw outs.
IMHO the largest variable in my testing has been the auto shutoff at the pump. You can see a few cases where one reading is unusually low followed by the next one being unusually high or visa versa. Those are most likely directly due to the auto shutoff inaccuracy. Course those pairs average out the error cleanly as long as both fills are in the list...
So I'll keep adding data, it would be nice to get a good visual graph of the three sets on top of each other. In my case it's somewhat too bad I upped the tire size in the middle like that but I'm not like altering my life over the data collection :D I wanted new tires!
Good god, I have not seen a thread like this outside of BITOG in a long time. Go outside and do some adventuring fella's. :thumb3:
Do you have a date for each fill up? I need that for the time axis.
It's ok, his personal opinion does not jib with any facts gathered by hundreds of people that actually have tested the product. Guys like him live on the internet as opposed to the real world where facts outweigh opinions. It's a shame he does not put his effort and obvious knowledge to a better and more positive use.
Just as FYI: Just returned from vacation. From Allentown, PA to Port Clinton Ohio-Columbus, Ohio and return. T4R loaded up and averaging 75-80 MPH and local driving. Fuel Mileage average for trip was 20.9 and forgot to mention running with AC.
Same Trip last year and average was 19.9. Tangible result is a 1 MPG increase.
I Added 2 more tanks to eco block group and plotted mileage...
After plotting the data, the changes from stock to over size tires, then the addition of the eco block becomes even more clear.
There is a slow downward trend in my stock MPG over time, likely due to my adding bumpers, winch, battery and skids during that time increasing weight. However the last few tanks seem relatively stable as I slowed down my "building". There is also no indication of any seasonal change in MPG due to gas reformulations, we have low MPG gas here year round now :(
Laying the KO2 sequence and finally the Eco Block added sequence on top of just the end portion gives the clearest picture of the MPG changes due to those two items.
Calculating only the last 8 fills of the stock/no eco block sequence instead of the entire thing and the numbers look like this:
Lifted, 265 (stock size) Toyo AT2 tires
18.22 + 17.93 + 18.48 + 18.08 + 18.03 + 18.26 + 18.61 + 18.38 / 8
18.249
Same as above but 275 BFG KO2s
16.8 + 17.66 + 17.31 + 17.18 + 17.66 + 17.51 + 17.38 / 7
17.357 - 0.892 MPG
Same as above but with the Crawford Eco Block
18.15 + 18.21 + 18.66 + 17.92 + 18.27 + 18.45 + 18.11 + 18.17 / 8
18.24 + 0.886 MPG
Results
* 0.9 MPG drop from Stock AT to 275s
* 0.9 MPG increase using the MAF spacer with all other variables constant.
OH-BOY-ITS-THIS-THREAD-AGAIN.jpg~original
What's wrong with this tread? He's giving real data (and yes I realize there are tons of variables that go into fuel economy numbers) and this is a better thread than one of at least 5 started this summer about the 2016 4Runner and numerous other topics that have been beaten to death and then had their lifeless corpses beaten further.
I love this thread....
Started off with the general consensus that this was snake oil. Then people started testing and, eventually, I think it's been proven that it works.
Lots of discussion on why it works which is also cool...
And now people giving even better, long term data...
Much better than the "What tire options do I have for my Limited?" threads.
Thanks guys :)
Yeah, I mean I recognize that it's a bit of a dead horse, but people were asking for data and I decided to silently collect some and just show what I found. It takes a LONG time (months) to collect MPG data before you can begin to see patterns, so bringing up a dead subject is the only way to present the info...
Anyhow! I think I've done all I can here. It's already paid for itself in gas savings and I'm going to leave it in for the time being.
Warthog out!
If I could multi-dislike your post I would.
This thread is one of the best we've got on this forum, full of information, inter-linked with a tacomaworld thread, intelligent discussion (even engineers chimed in), and on top of that, the owner of the companie that makes the ecobkocks had a talk with us.
Hope you have fun in the tire size threads.
Still have my EB installed, clearly made a small difference (around 5%+), I just didn't collect "scientific evidences" to show up here.
I agree with you, i was one of the first to install the Eco-Block, and actually went up to Quirts shop ( Crawford Performance ). Very stand up guy, and i wish him all the best.
Thanks for the kind words! I have made a lot of friends over the years selling our Eco Block fuel saving device.
Quirt
Southshore
