Lockers are also a gimmick for noobs with no driver skills. All you really need is wheels and skillz. He wouldn’t know though because he uses atrac.
Yea that’s not true at all.
Obviously we haven't wheeled the same things in our lives as each other. Lockers make all the difference in the world, but also remember they can get you in far more trouble if you don't know what you're doing or your spotter sucks (read: much easier to get into roll situation).Lockers are also a gimmick for noobs with no driver skills. All you really need is wheels and skillz. He wouldn’t know though because he uses atrac.
I am a believer in crawl control.
Before buying my 4runner, I did a lot of research on it and I think I must have watched at least 50 different YouTube videos on it. I have seen quite a bit of videos where skilled off-roaders where stuck and couldn't get out until they used crawl control.
From what I understand, using MTS + Crawl control at the same time is the best for really bad situations. MTS gives the computer a little more information on what type of stuff you're stuck on, and helps crawl control determine what to do a little better.
I'll probably never use it as I don't do any crazy off-roading, but I think it's a cool feature to have.
i've read this twice in different threads about using crawl control and mts at the same time but my 2016 won't do it. is there some mod that can be done to make them work at the same time? sorta doesn't make sense since they do the same thing (as far as using brakes and throttles)
I tried locking the rear diff when stuck in sand but of course it will not work. Lockers are good when you got a wheel up in the air. And as others have stated, they can sometimes get you too far into the gnarly stuff or slide your ass out. Regarding the video of the taco using crawl control, a competent driver would be able to get out of. Granted crawl control is great if you are new to offroading or maybe need super focus on an obstacle.
You can’t have them simultaneously engaged. If you have MTS on then it will turn off when you engage crawl control and reengage when you disable it.
