crazydubman
Ya they are pretty heavy. A lot of the weight is from the center rubber beadlock. Probably 8-10lbs right there. Maybe in the distant future I may look into having some PVC ones made like the 16.5 steel hummer wheels out there.
Ya your skid took a pretty good hit. I will keep an eye on everything when I'm out in Slick Rock at the end of the month.
I have pondered a super charger but to get a complete setup working right with all the bells and whistles, I would think that a 4.0 or 4.7 swap would be right in the same ball park, around 5-6k right? You would then have more power and all in stock form.
I definitely will be regearing to 4.88's due to the extra weight and trying to pull hills. for some reason my coolant temps like to start creeping up on long climbs. May need to swap in a new radiator at some point as well. I think its the original. The cooling system (Tstat and water pump) was already gone through when I did the head gaskets.
