Atlanta_man
It remembers the last speed even after a full stop. Just tap the lever up once you reach 30+ mph. It's been many years since I've had a car that did not forget the last set speed.
Atlanta_man said:It remembers the last speed even after a full stop. Just tap the lever up once you reach 30+ mph. It's been many years since I've had a car that did not forget the last set speed.
tkr128 said:I know my 03 has it. I've only used it once after having to slow down. It can hit the gas pretty hard to get back up to speed though.
Not sure about the full stop. I'll try it out soon.
tipotex said:My '05 (SR5 V6 4x4) remembers/returns to the set speed unless, as indicated above, the cruise control is completely shut off. Slowing to a crawl or stopping won't erase the set speed. IIRC, same on my '00 Celica GT-S. Hard to believe there's an exception for an '04 4Runner...
Kmvreter said:Off to the dealer I go...
sharp4runr said:I've just verified on my morning commute and it does function on a 2004 SE as well. I don't see Toyota changing the Cruise Control function between production years so yours may be faulty...
Originally posted by NoDak
ok i went out and got the 04 owner's manual and here is a direct quote:
the cruise control allows you to cruise the vehicle at a desired speed over 40km/h or 25mph even with your foot off the accelerator pedal.
cancelling the preset speed:
a. pulling the lever in the "Cancel" direction and releasing it
b. depressing the brake pedal
if the vehicle speed falls below about 40km/h or 25mph, the preset speed will automatically cancel out.
if the vehicle speed drops 16km/h or 10mph below the preset speed, the preset speed will also automatically cancel out.
resuming the preset speed:
if the preset speed is cancelled by pulling the control lever or by depressing the brake pedal, pushing the lever up in the "+ RES" direction will restore the speed set prior to cancellation.
however, once the vehicle speed falls below about 40km/h or 25mph, the preset speed will not be resumed.
note:
each tap of the "-/+ SET" lever changes the set speed by 1.6km/h or 1mph.
not mention in the owner's manual but you can also cancel the system by putting the transmission into neutral or (not tested) applying the e-brake.
Tested mine on a trip this evening and it behaves the same as yours.tkr128 said:Okay, just checked my cruise control on my commute home. Took me about 35 miles before I could find an empty stretch to do it. My 03 does not retain the speed after you come to a stop (or less than 25mph).
