cruise control problems
Hesk11dog
I have a 97 limited, 2.5'' coil spacers with 265/75/16's. It is my daily driver and I take it on 2 hour trips every other week. The cruise control light on the dash lights up when I hit the button but it will not set the speed when i pull it down. Not sure if it is the CC module or just a wiring issue. I am new to this forum and it is freaking sweet.
No it hasn't came on because of that, thought it would throw a code but never did. I started checking some of the wires but didnt find anything unusual.
looks like it is this, i would like to fix it without going to a dealership but if it is the ECM, I'm screwed on that end
My '97 has a similar issue. Sometimes it works as it should, more often it doesn't work at all. Thanks [MENTION=84995]jkoni426[/MENTION] for posting that diagram!
My CC hasn't worked in years. I just bought an ECU off E-Bay for $30. That should fix it. Thanks for this thread.
I just purchased my 97 and have had a similar issue. Mine is a 5-speed and for some reason the cruise control won't always work but if I sort of push the clutch pedal left and right with my foot it will start working. Not sure why it happens or why that works, just the advice the PO gave me and it works, so if you have the 5-speed that might help you out.
Same reason I asked the OP about his brakes. There's a sensor/switch down at the pedal, and on manual trans they're on both the brake and clutch pedals. Your sensor is bad so the CC thinks you have the clutch pushed in which would over rev the engine if the cruise stayed on obviously.
With my 5-speed 3rd gen, I have to pull the clutch ALL THE WAY OUT with my foot for the cc to work. If the clutch isnt all the way pulled back, the cruise control light will still come on, but it wont set.
Do your brake lights work? If they aren't the cruise won't set.
My brake lights do work. It sounds like 5 speed T4R's have a bit of a problem with the CC. I'll try the peddle jig tomorrow and the millimeter checking connections if that fails. Thanks for all the help, who needs cruise control anyway
Cruise control issue revisited- New problem
Hey guys,
I'm new to the forum so please excuse me if I miss something here. I also cannot post a new thread yet, so this is the closest one I found. To preface my question, I've read through all the threads i could find and even used the alternate search tool on the home page but haven't found anything that has helped resolve my problem. I have a 1998 T4R, 4x4, 3.4L V6, with auto transmission and the Ford cruise control (as opposed to the Denso one the shop manual mentions is available). My problem is that the CC light will come on when engaged in park. The light will stay on when placed in drive but CC will not engage. If turned off while in drive it will not turn back on. It cannot be turned on at all when in drive. Here is what I've tried:
1. checked all fuses based on shop manual and these threads
2. Brake light (stop light) switch has been changed and checked for proper clearance. All lights work ok
3. Cable from CC computer to throttle body not binding or deformed
4. CC computer connector and wires appear to be fine
5. No codes at all appear on ECM with code reader. No fault lights or any other abnormal indications from the vehicle of any kind.
6. I have not checked the basic functions of the CC switch yet because i know the on/off switch works and until I can get it to turn on/off in drive the other functions are of secondary concern (I think...).
The troubleshooting guide in the shop manual is a little confusing and appears to need a couple of special tools, most importantly an inline connector to allow for voltage/signal readings (if I'm understanding it correctly). My final thought is to just take it to Toyota and see if they can find the problem, but wanted to check the vast knowledge base here first. Any help or suggestions is greatly appreciated.
Mine had this for a few years after I bought it. Turned out to be internal leak in slave which then became a driveability issue. Dangerous and a truck became a menace. Very easy to swap in new mc sc, it fixed it real buttery like.
DaMokey,
Thanks for the reply and feedback. Mine is an auto transmission so all I can mess with along those lines is the stop light switch behind the brake pedal. I already changed that out and adjusted it so that has been isolated as causing the problem. Not sure what you are referring to when you said, "...new MC SC" but I assume those are related to a 5-speed and not auto tranny?
DaMokey,
Yes. Clutch master cylinder and slave cylinder.
I have the factory installed security system on my T4R. Does anyone know if it is tied into the cruise control at all? The security system works but is doing some random crazy things here and there like having the lock/unlock chime work intermittently or the auto lock feature working sometimes but not others. I was just wondering if a glitch in the security system might cause the cruise control to not engage.
SOLVED- Cruise control problem
So I solcved my cruise control problem mentioned in a previous post. It turned out to be the cruise control computer (with the throttle cable attached to it). The cable wasn't stuck or anything, I guess the module just had an internal error. I found one off a 2000 T4R in a salvage yard and picked it up for $10. Problem solved! Cruise works like a champ now.
AndiGarage
