Custom Rola Roof Rack
Titanpat57
Senior Member
Hi Guys...
Wanted to put this out there and get some input...either good or bad, I just appreciate the honesty.
Several weeks ago we discussed the Rola Roof Rack with extension(s) and I offered up some pictures. I found a Rola on Craigslist for 40$, and purchased the other two extensions for about 60$ a/p.....so to date that's an investment of 160$...not to bad.
At the time of the thread I only had one extension, but after further review, I decided I wanted a second extension to bring the rack out to the full length. I happen to like the Rola design, and feel it lends itself nicely to the 4Runner's lines. Although I also like the flat rack designs, I feel they don't "follow" the curvature of the roof line. Obviously, I know why the manufacturers do it...I would just like to see a bit of bow so it doesn't appear so flat..but again, that's just me.
So I spot welded the pcs. together, and measured the bow in the roof, and think I have it pretty close now. Before I put the final welds to it, I figured I'd put it out here to get your opinions. I will still need to weld support feet in the front, but this should give you an idea.
Here are some of the original pix, and then a few with all the extensions.
Thanks in advance
IMG_20120412_155501.jpg~original
IMG_20120413_140707.jpg~original
IMG_20120419_222133.jpg~original
IMG_20120419_222144.jpg~original
IMG_20120420_114518.jpg~original
IMG_20120420_114530.jpg~original
You may want to hit that with a bit of Rustoleum or PC it so it doesn't rust/corrode, but I'm sure you knew that.
It looks good, but I'm not a fan of bolting baskets on top of roof racks...just not streamlined enough IMO and it's sort of redundant. Are there any provisions to mount it directly to the factory rails?
Spddmn133
