I own an '04 SR5 V8. When I bought the truck, I thought it *didn't* have the tire pressure monitoring system. I thought it came only on the Sport and Limited. I found out last week I was wrong. The light started flashing. This was after I mounted new snow tires on conventional rims/valves.
After going through the various threads on the system, I concluded that the problem must be the spare since it appears that the conventional valves on the new wheels don't send out a low-pressure signal. The spare was around 29 psi so I topped it up to 32. Drove around for the weekend and the light has not gone out. Annoying to have a flashing warning light on a nearly new vehicle.
Can anyone confirm how the tire pressure monitoring system works with non-compliant valves? That is, if the valve on the tire does not have a pressure sensor, does that mean the system detects a low pressure condition or does it assume that the pressure is okay?
